ABS and ESP Lights
G8ANT
ABS and ESP Lights
Post by G8ANT » Sun Jan 20, 2008 1:32 pm
Hi to you all, ime a new member and wonder if anyone can advice, Had a little blast of my RS4 B5 last night came through a roundabout and ESP and ABS lights came on and stayed on,i tried pressing the ESP switch nothing happened, i then pulled over and restarted the car and every thing is ok again, any ideas or should i get it checked out on vagcom, thanks for any advice given,
Peakz
RE: ABS and ESP Lights
Post by Peakz » Sun Jan 20, 2008 2:33 pm
Get it VAG-COM'd.
I had this last year and it turned out to be corroded contacts on the ABS controller and only last week the same happened again and VAG-COM stated the ABS sensor on the offside wheel had failed.
Good luck!
G8ANT
Post by G8ANT » Sun Jan 20, 2008 5:48 pm
Hi Peakz was it happening regular and have you solved the problem now, thanks
2002 RS4 B5 Misano Red
Peakz
Post by Peakz » Sun Jan 20, 2008 9:46 pm
ABS controller got gradually worse over a period of 6 weeks or so I think.
I haven't got my ABS sensor fixed yet, error has only come up once so far but it'll get replaced imminently.
Return to “DTC / VCDS”
