Exhaust manifold porting
MarkB
Post by MarkB » Wed Jan 16, 2008 9:21 pm
Anyone seen a how-to for exhaust manifold porting on the B5 S4/RS4?
I'd be interested to see some before and after pictures.
Mark
Chubby
Re: Exhaust manifold porting
Post by Chubby » Thu Jan 17, 2008 9:06 am
MarkB wrote:Anyone seen a how-to for exhaust manifold porting on the B5 S4/RS4?
I am in the middel of porting and polishing my RS4 heads - will try and get some pics for you.
Regards,
R.
RS4 Misano Red (The Fast Colour) - A Few Extras = 550bhp - In Love Again - Now broken - Hate the Bitch... Has to go...
GT-R arriving 14/05/09 - Too many toys - not enough time...
MarkB
RE: Re: Exhaust manifold porting
Post by MarkB » Thu Jan 17, 2008 9:09 am
Great Thanks
Mark
JonnyX
Post by JonnyX » Thu Jan 17, 2008 10:33 am
Doug did mine for me. It was very easy (for me) :-).
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
MarkB
Re: RE: Re: Exhaust manifold porting
Post by MarkB » Thu Jan 17, 2008 10:34 am
JonnyX wrote:Doug did mine for me. It was very easy (for me) :-).
Yes. How much cost? Does he do them on exchange?
Mark
s4woody
RE: Re: RE: Re: Exhaust manifold porting
Post by s4woody » Thu Jan 17, 2008 11:34 am
mark there easy to do..just fix a gasket to the face of the manifold and open it out to the gasket port size..making sure you taper back into the manifold..ive done a few..
GARTH ROAD MOT CENTRE LTD
020 83353032
MarkB
Post by MarkB » Thu Jan 17, 2008 11:37 am
The worry is that the exhaust manifold is tubular so you don't want to take away the strength. Which is why Doug TIG's then after modification.
Mark
s4woody
Post by s4woody » Thu Jan 17, 2008 11:40 am
whats the worry..i TIG also..oh and MIG..oh and Gas..oh and BRAZE..oh and ARC..and ive also been known to solder..
020 83353032
MarkB
Post by MarkB » Thu Jan 17, 2008 11:43 am
So at what point would I know I have to put some more metal back after grinding away the surface?
Mark
s4woody
Post by s4woody » Thu Jan 17, 2008 11:48 am
ha ha ..when you see a hole...
the face of the manifold is what your gonna be opening up the most..which is quite a sturdy piece of metal..once you start to go inside the manifold then you have to be carefull and taper it ..
if you get some engineers blue and offer up a manifold to a head you will see just how much the posrt on both differ..then you work from there..as a novice of course..
020 83353032
tdiquattro
Post by tdiquattro » Thu Jan 17, 2008 1:30 pm
I am not so sure woody,
If you look for the previous thread where we discussed this you can see the weld is the thing that needs grinding back not the face of the manifold, it actually sits proud of the inside of the pipe.
So Mark has a very good question, how do you grind out the weld and re-fill it, but make sure the mani is still strong enough and there are no leaks. You cant see the pipework from the outside to check the weld as it is covered.
Nige'
2000 silver S4 Saloon
MarkB
Post by MarkB » Thu Jan 17, 2008 1:38 pm
Mark
tdiquattro
Post by tdiquattro » Thu Jan 17, 2008 1:41 pm
Pic...
Nige'
MarkB
Post by MarkB » Thu Jan 17, 2008 1:44 pm
Seeing the pic again I'm thinking it doesn't look too bad. Obviously could be better but with the state of tune I'll be running probably safer to leave it alone.
Mark
tdiquattro
Post by tdiquattro » Thu Jan 17, 2008 1:55 pm
Yep Mark,
I'm in the same situation, just about to get the engine out and thinking about this mod, but it sounds risky as you cant inspect the weld on the outside, and with so many problems noted on the ebay manifolds with the welds isn't this introducing the same unpredictibility?
How long have the MRC moded ones been in and working for?
Also the diameter of these three exhaust port tubes are the same as the one on the turbo end of the mani so isn't that where the restriction is. Getting rid of the lip of the weld has to be a good thing but too risky I think.
Nige'
