RS4 standard height. Help needed.
2.7 V6 30v biturbo - 380 bhp
Tomasz
Post by Tomasz » Tue Jan 08, 2008 3:54 pm
Last friday I've changed my suspension (by Quattro GmbH) to brand new Bilstein PSS9 .
Nowadays I'm going to adjust PSS9 to maintain standard height (it would be important not to cut down on any milimeter because as a stock car it is low enough) but only piece of information I know is the stock car height: 1366 mil measured on 255/35/18 tyres and unleaded car. Am I right? Because some sources pass it as 1400 mil.
I would like to know any other data of the stock car such as height from the ground to the bottom part of the front/rear bumper or other methods to state the height. :idea:
Any ideas?
Thanks in advance,
Tomasz
:nogarors4:
tdiquattro
RE: RS4 standard height. Help needed.
Post by tdiquattro » Tue Jan 08, 2008 5:21 pm
I know the ride height for coilovers is usually measures at all 4 wheels from the ground to the underside edge of the lip of the wheel arch. That is the height usually quoted. Not sure what the standard cars are though?
Nige'
2000 silver S4 Saloon
simoncotton
Post by simoncotton » Tue Jan 08, 2008 6:05 pm
not sure, but I need to raise the height of my car - its on H&R Coilovers and is only 4 inches off the ground and catches on catseyes, very unpractical!!
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Jan 08, 2008 10:21 pm
Let us know your thoughts on the PSS9 kit. Sorry I can't be of help
Virdee Autos ~ 07950-526592
Tomasz
Post by Tomasz » Wed Jan 09, 2008 10:58 am
So far so good especially comparing to "old" one but I expect much more fun after adjusting it :lol: . As you probably know it possesses 9 modes of damping. Now (till Thursday) I'm driving the most comfortable (no 9) mode, which is more or less like the stock suspension, but I'm going to shift it to number 7 - much stiffer but, I hope, still giving minimum comfort for every day driving.
Anyway, I feel like having new, quicker toy.
What a pity that PSS9 gives no possibility to control sport/race/comfort mode from the car (like TEIN product - but not made for RS4).
Cheers,
Tomasz
:nogarors4:
tdiquattro
Post by tdiquattro » Wed Jan 09, 2008 11:31 am
I was looking at TEIN, just superb quality and design, the electronic damping control is fantastic, yep it's a shame they don't do a setup for the B5 S4/RS4, very good value as well, :( , (importer is based in Milton Keynes).
Nige'
RSpimp
Post by RSpimp » Wed Jan 09, 2008 1:12 pm
bilstien have just released electronic control for there ps9s .. but dont know if they have them for the rs4 yet .. but definatly seen them in a mag somewhere !
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Wed Jan 09, 2008 8:23 pm
Now that sounds good!
Keep us posted
ewill
Post by ewill » Thu Jan 10, 2008 12:02 am
I've been trying different settings from 9 to 4. Noting that the adjustment is for both high speed bump and rebound simultaneously, my impression is that bump is relatively too firm compared to rebound. So what I think I'd really like is the no.9 bump setting but the no.4 rebound setting. Anyone with similar views? Or experience with making changes like this?
ewill
Post by ewill » Thu Jan 10, 2008 12:07 am
Oh, and on the height issue, the Bilstein specs give you a range of height adjustment. I went for the higher end of that range and the height of the car appears very similar to stock, about two finger width gap between the top of the stock size tyres and the arches all round. I know this is not the right way of measuring, but I don't have the measurements from the ground.
EDDY,G
Post by EDDY,G » Thu Jan 10, 2008 12:08 am
http://www.ca-automotive.co.uk/variants ... nt_id=1845
these are the new bilstien electronic controled dampers.....hope they make them for the rs4
B8 S4 red
335D TOURING 700nm. sold
09 V10 RS6 GUNMETAL
EVO9 MR FQ360 480/450 sold
04 rs6 black sold
01 noggy rs4 , short shift ,ottinger rs6 upgrade biiig break kit , bilstiens, no cats + mrc custom remap !....04 ebony rs 6 with.. tints and all the toys ! sold
e46 alpina b3.4 s..sold
e39 m5 ..sold
e36 m3 evo..sold
civic type r track bitch..sold
Tomasz
Post by Tomasz » Thu Jan 10, 2008 12:36 pm
According to PSS9 height possibility I've got it as high as it was possible and my car looks rather like RS4 Allroad but even than cornerig isn't any problem.
I'm looking forward handling after adjusting. 8) Should be fab.
These new toys... :lol:
Will report my feelings after final adjusting (it's today night).
Cheers,
Tomasz
:nogarors4:
tdiquattro
Post by tdiquattro » Thu Jan 10, 2008 9:38 pm
Here is an old thread on ride heights,...
http://www.rs246.com/index.php?name=PNp ... ring+rates
Nige'
don
Post by don » Fri Jan 11, 2008 1:30 am
I have my PSS9's set on #4 setting and set approx 10 mm lower than standard. Handles significantly better than stock (inc. H&R fat bars). Though I think rebound is still a little soft and #3 setting would be worth trialling.
I agree with PSS9's set at full height it does look like an RS4 All Roader but still handles great.
PSS9s are great for those who want an excellent road handling car. However, for regular track junkies Stasis is still probably the way to go.
ewill
Post by ewill » Fri Jan 11, 2008 6:20 am
Be careful about using ride heights at the extremes - for some reason known only to themselves, Bilstein provides for a lot more height adjustment on the PSS9s than can be properly accomodated. I started with the ride too low at the rear and it felt like it was riding on the bump stops. Stick within the adjustment range that Bilstein specifies, rather than how far you can wind the sleeve up or down.
I'm now looking at revising the valving to have a mid position 4/5 with high speed bump equivalent to the current 9 and rebound equivalent to the current 4, and go from there. Apparently, this is not very difficult to do.
Users browsing this forum: No registered users and 61 guests
