Max power on standard injectors?
2.7 V6 30v biturbo - 380 bhp
MarkB
Post by MarkB » Fri Jan 04, 2008 4:08 pm
What is about the max power that can be got out of an RS4 on standard injectors and fuel pump?
Mark
Särås
RE: Max power on standard injectors?
Post by Särås » Sat Jan 05, 2008 12:24 am
I say round 500bhp +-20bhp... All depends on a lot of stuf...
Best regards
Harper--D
Post by Harper--D » Sat Jan 05, 2008 1:12 am
Depends on what heads, S4 heads your looking at 400bhp, but rs4 are closer to 500bhp IIRC.
Dave.
White MK2 Golf.. Slightly modified :D
MarkB
Re: RE: Max power on standard injectors?
Post by MarkB » Sat Jan 05, 2008 9:10 am
Harper--D wrote:Depends on what heads, S4 heads your looking at 400bhp, but rs4 are closer to 500bhp IIRC.
This is specific to RS4 type heads and inlet manilfold
Mark
musty1
RE: Re: RE: Max power on standard injectors?
Post by musty1 » Sat Jan 05, 2008 10:02 am
on rs4 heads and inlet manifold around the 500bhp as harper-d says on s4 lower due to spray pattern
1.9TDI A6 are sh*t wrong forum
Harper--D
Post by Harper--D » Sat Jan 05, 2008 10:17 am
That is why i said depends on the heads to start with.
Dave.
Blue_Thunder
Post by Blue_Thunder » Sat Jan 05, 2008 11:16 am
Do the RS4 heads allow you to run much more aggressive timing?
I'm interested to know what makes the RS4 more powerful that the S4 using the same injectors and fuel pump, as Doug had mentioned in another thread referring to the difference between RS4 and S4 engines that
Doug_S2 wrote:internals are different but only stronger - nothing will give better performance.
MarkB
Re: RE: Re: RE: Max power on standard injectors?
Post by MarkB » Sat Jan 05, 2008 11:52 am
Blue_Thunder wrote:Do the RS4 heads allow you to run much more aggressive timing?
It's the heads, cams and inlet that makes all the difference. These push the power further up the rev range, probably due to them being larger so aren't so efficient at lower rpm.
Mark
Virdee Autos
Trader (Expired)
RE: Re: RE: Re: RE: Max power on standard injectors?
Post by Virdee Autos » Sat Jan 05, 2008 8:01 pm
Thats what makes 90 odd bhp?!
Virdee Autos ~ 07950-526592
Ads4
Post by Ads4 » Sat Jan 05, 2008 8:14 pm
+ the K04s of course :wink:
Adam.
MRC B5 S4 Avant.
MarkB
Re: RE: Re: RE: Re: RE: Max power on standard injectors?
Post by MarkB » Sat Jan 05, 2008 8:30 pm
R33V-Spec wrote:Thats what makes 90 odd bhp?!
It's what puts a K04 RS4 about 50bhp ahead of a K04 S4 when the rest of the exhaust, downpipes and intercoolers etc are the same. All in the heads, cams and inlet, IMO
Mark
Virdee Autos
Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: Max power on standard injectors?
Post by Virdee Autos » Sat Jan 05, 2008 8:45 pm
Ok fair enough
