RS4 Conrod BEARINGS different from S4???
2.7 V6 30v biturbo - 380 bhp
surfpilot
Post by surfpilot » Thu Dec 06, 2007 2:42 pm
I ordered a set of Conrod Bearings (std. size) for for my RS4(ASJengine) from the States.
What arrived was almost .5mm thicker!
Looks like std.RS4 conrod bearing is NOT thesame as std.S4 ones! :(
dodgydave
RE: RS4 Conrod BEARINGS different from S4???
Post by dodgydave » Thu Dec 06, 2007 3:08 pm
They're not! The RS4 bearings are thinner because of the bigger bolts used on the RS4. Use the search, this has been discussed here before. Also I wouldn't use anything different than the stock bearing shells because the top once are extreemly strong sputter bearings.
Never enough...
okkim
Post by okkim » Thu Dec 06, 2007 8:56 pm
The bearings ID is the same, but OD os different. The RS4 bearings are also about 4 times expencier... I paid 470€ of those.
foggy75
Post by foggy75 » Sat Dec 08, 2007 11:44 am
If you order the bearings from Audi they come without the oil feeder holes which are the original type.
I got told these was the same as s4 bearings apart from these holes when i got mine replaced i had these hole put in.
surfpilot
Post by surfpilot » Sat Dec 08, 2007 11:52 am
hmmm strange...we measured the S4 ones and it is almost .5mm thicker compared to the RS4 ones...both standard sizes.
okkim
Re: RE: RS4 Conrod BEARINGS different from S4???
Post by okkim » Sat Dec 08, 2007 10:18 pm
foggy75 wrote:If you order the bearings from Audi they come without the oil feeder holes which are the original type.
S4 and RS4 bearings have different thicknesses!
So you mean that if you order bearings from Audi, you don't get originals? (because they don't have holes?)
The bearings are different, no matter what someone else says. I can also measure S4 ans RS4 bearings to have a proof...
Users browsing this forum: No registered users and 115 guests
