Been looking around at warranty cover and found this -
Premium £ 473.69
Claim limit £7000
12 months cover
Extra cover i selected - Turbo Charger, ABS ,Air Con , 4 wheel drive.
Have a read and see if you think the gearbox etc is covered etc?
Sorry everyone i know its alot of reading but if we can find a good policy between us all we may save a few quid on audi price's. Im out of money now i have brought the rs!
FREE vehicle check with every policy!
For your peace of mind every one of our warranties includes a unique FREE non-compulsory safety check carried out by one of our independent approved repairers. Our national inspection service offers you the peace of mind that no major problems exist and your car is safe and roadworthy. For your convenience a free collection and delivery service is provided... more
Cover against breakdown due to WEAR & TEAR included as standard
"Wear and tear" is the expected reduction in performance of a part due to the cars age, mileage and/or use. Many companies exclude it, others charge a premium to cover it. All our policies cover breakdown of an insured part attributed to wear and tear. ... more
No increase in premium for high mileage cars
Most warranty providers penalise high mileage car drivers irrespective of whether a claim is made or not by charging more for the warranty. Click4warranty don't, instead we require a contribution toward the cost of repairs in the event of a valid claim. This is known as "The Z Scale" and means instead of paying a premium loading at the outset, there is a contribution for "betterment" in the event of a claim. Not unreasonable as the car is in better condition than it was before
Parts and labour covered
Your Click4Warranty policy pays toward the costs of parts and labour for repair or replacement of an insured component.
Choice of claim limits
All Click4warranty policies have a choice of three substantial claim limits, £3,000; £5,000 and £7,000. This is the maximum amount payable on each and every claim.
Unlimited number of claims.
You can make an unlimited number of claims and we will apply the single claim limit to each claim. The maximum amount we will pay "in total" during the term of the policy is set at the Glass's Guide retail value of your car at the time of claim.
Cover from day one
Sudden, unknown and unexpected failures are covered from the day your policy starts.
No annual mileage restriction
The Click4Warranty policy has no limit on the annual mileage you drive. Your car will continue to be protected by a Click4warranty policy until it has covered 150,000 mile
Claims handled over the 'phone
All you need to do is pick up the phone and call us. To keep the process quick and simple we process everything over the 'phone. ... more
Claims settled directly with the repairer.
Wherever possible, to avoid your being out of pocket, we will settle authorised claims directly with the repairer. ... more
Vehicle Recovery included
Up to £100 towards the cost of recovery to the repairing garage
Replacement Car Hire included
Up to £30 a day towards the cost of a replacement vehicle while your car is being repaired.
Overnight accommodation and rail fares included
Up to £60 towards hotel expenses or a return rail ticket.
European Cover included
Up to 60 days cover for driving in the Republic of Ireland and mainland Europe
Clear and definitive Terms & Conditions
In 2003 the Insurer saw an opportunity and became a partner, immediately providing us the enviable flexibility to write terms & conditions that are clear and definitive.
21 day money back guarantee
Unlike other providers we allow you 21 days (not the standard 14) from the date the policy was purchased to cancel your policy and receive a FULL refund.
Cover may be transferred to new private owner
A warranty is a valuable selling tool if you decide to sell your car. The warranty may be transferred to the new owner, simply call us to request the transfer and we will transfer the balance of your policy to the new owner. We do require a £25 contribution from you toward the administration costs. Conditions do apply (for example we cannot transfer the policy if you sell your car to a motor dealer)
Insured Parts are listed under the following headings, any item not specifically described below is not insured.
ENGINE
The rocker assembly, including hydraulic followers, inlet and exhaust valves [not burnt valves], springs and guides, cylinder head [not cracks and de-coking or porous heads], cylinder head gasket [except skim], push rods, camshaft and followers, timing gears and chains [excluding tensioner], oil pump, pistons and rings, cylinder bores [excluding porous bores], con rods, gudgeon pins and bearings, crankshaft and bearings, inlet manifold, flywheel and ring gear. Timing belts are covered provided that they have been changed in accordance with the manufacturers schedules. In the event of a claim YOU will be required to provide proof that the timing belts have been changed in accordance with the manufacturers schedules. Failure to do so may invalidate YOUR claim.
MANUAL GEARBOX
Internal gears, internal shaft, synchromesh hubs, selectors, bearings and bushes and transfer gears.
AUTOMATIC GEARBOX
Internal shafts, gears, clutches, brake band, valve block, governor, oil pump, bearings and bushes, servo, drive plate and transfer gear.
DIFFERENTIAL
Internal crown wheel and pinion, gears, shaft, bearings and bushes, thrust washers and spacer.
CONTINUOUSLY VARIABLE TRANSMISSION CTX
Internal clutches, planetary gears, reduction gears, shafts, variable pulleys, thrust link drives, internal seals, bushes and bearings.
PROPSHAFT
Universal joints and couplings.
TORQUE CONVERTER
Failure of any internal mechanical PART(s)
CASINGS
If any of the covered PART(s) fail and this damages the casings, the casings will also be covered.
WHEEL BEARINGS
Front and Rear Drive Axle Wheel bearings, Both front and rear wheel bearings.
ENGINE COOLING SYSTEM
Viscous fan coupling , water pump , thermostat housing, thermostat, heater matrix , Radiator , oil cooler.
WORKING MATERIALS
Oils, oil filter , anti-freeze , working materials are covered only if it is essential to replace them because of the failure of a PART(s) which is covered under this POLICY.
CLUTCH
Centre plate, pressure plate, release bearing, oil contamination [centre plate only] , master and slave cylinders, labour costs included.
FUEL SYSTEM [DIESEL AND PETROL]
Carburettors , mechanical or electrical fuel pumps , injection pump, automatic choke , lift pump , tank sender unit.
BRAKES
Brake master cylinder, Wheel cylinders, restrictor valve, brake caliper seals, Servo.
STEERING [INCL. POWER ASSISTED STEERING]
Steering rack and pinion [not gaiters], steering box, idler box, power steering rack and pump, power steering reservoir.
ELECTRICAL SYSTEM
Starter motor and solenoid including pre-engagement mechanism and bendix drive, alternator, diode pack, coil voltage regulator, indicator relay, front windscreen wiper and washer motors, rear windscreen wiper and washer motors, window and sun roof motors, indicator flasher relay, electric window switches, sunroof switch, centralised locking, heater fan motor, distributor, electronic ignition amplifier, thermostatically-controlled radiator fan motor, horn and multi-function stalk switch.
FRONT AND REAR SUSPENSION
Coil springs, Hydrolastic displacers and hydropneumatic spheres, upper and lower wishbones, ball and swivel joints.
ENGINE MANAGEMENT (ECU)
Engine electronic control unit.
FUEL INJECTION SYSTEMS
Throttle body, airflow meter, idle control valve, cold start valve, warm up regulator, overrun cut off valve, throttle potentiometer, fuel accumulator, pressure regulator, map sensor [except injectors and heater plugs]
FRONT WHEEL DRIVE
Drive shafts including constant velocity joints universal joints and couplings [not gaiters]
REAR-WHEEL DRIVE
Half shafts, rear-wheel external drive shafts including constant velocity joints, universal joints and couplings [not gaiters]
rs6 warranty. Cheap?? What do you all think to this ?
- mattysupra
RE: rs6 warranty. Cheap?? What do you all think to this ?
Isnt the general rule to get an inclusive warranty where everything is included unless specifically excluded? I haven't read all this but I can see that it's an exclusive warranty where nothing is included unless specifically included. It does seem to suggest most of the gearbox is covered though, albeit the gearbox ECU could be wriggled out of if it failed.
Fen
'03 RS6 Avant in ebony black/grey leather, black optics, solar roof, dippy & foldy mirrors, RNS-E, Bluetooth, West Tuned SOLD
looks ok, but electronics are generally not covered. but they also don't go wrong.
Users browsing this forum: No registered users and 140 guests
