The vents no longer emit an air flow.
Heater/air-con has packed up.
Zilch. Nada. Nothing. Kaput. I think it's broken.
This has been an intermittent problem for the last week but is now permanent and i now need to drive with a window open to keep the interior from misting up. Has the fan broken or could it be a fuse? Or a whole new heater unit needed? I know nothing (nada. zilch.) about the heating system so would welcome some advice please!
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
RE: Heater/air-con has packed up.
Check the fuse first, at the very end of the dash (nearside), the panel has diagram if I remember correctly.
Could also be the brushes on the heater motor but that would get gradually worse over a longer pweriod, new brushes are only around £50 fitted from your local washing machine repairer.
I can't remember if the resistor pack on these is susceptible to failure but that's another cause I guess.
Hmmm, my first double-post!
Adam - do you have access to VAG-COM?
Any fault codes should give you a clue to where the problem lies.
Clive
Re: RE: Heater/air-con has packed up.
It's not too late to remove it...or are you just trying to get into 4th gear...? (as usualPeakz wrote:Hmmm, my first double-post!
Clive
RE: Re: RE: Heater/air-con has packed up.
If i rember rightly, there was a HVAC fault code on the rr day!
Dave.
White MK2 Golf.. Slightly modified
What double post?Peakz wrote:Hmmm, my first double-post!
Mark
Adam, if you're local to me any time soon I'd happily scan the car for you...
Mark
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D56
Coding: 00061
Shop #: WSC 06325
1 Fault Found:
01273 - Fresh Air Blower (V2)
17-00 - Control Difference
Means nothing to me
Coding: 00061
Shop #: WSC 06325
1 Fault Found:
Means nothing to me
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
Fault Code 01273 - http://wiki.ross-tech.com/index.php/01273
MarkB - Thanks for sorting out my double-post.
Looks like my 'Fresh Air Blower (V2)' is defective then?! New unit required? Trip to the stealers then...
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
Take the blower motor out from behind the glovebox first, a slightly fiddly job. Once it's out check the motor brushes for excessive wear, if they're worn it's a cheap fix. Shouldn't take you longer than forty minutes to take it out, even less to put it back once you've remembered where all the screws go.
that part number is for the control unit that sits in the centre console..about £570 inc vat..well thats stealer price anyways...
or to put it into ringlish..its your climate control panel..
the control panel without the heated seat unit is a mere £501.00 inc vat..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
tartan_rob
Or get one on ebay for peanuts.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Sheesh kebab £570!!
