Rods.
spen
Rods.
Post by spen » Thu Nov 22, 2007 3:53 pm
What options are there as far as replacement conrods for the S4 block?
I am aware of these brands, and here are my thoughts about them:
Arrow - Expensive, look very light, good for high rpm. Look well made, as much as you can tell in picture form.
http://www.arrowprecision.co.uk/details.php?id=66496
Pauter - Less expensive. Weird X shaped beam, I've never used a rod like that. Look heavy. Supposed to be able to take extreme loads. Dunno about the high rpm capability - they do look weighty. Pauter are a respected US brand.
http://www.pauter.com/4340_rods.htm
Someone from Oz selling sets on ebay. Right materials, good claims, ARP fasteners. No idea if they are any good. He doesn't name the manufacturer. Inexpensive.
Can I post an ebay link here without getting shouted at? The seller is called agropeti.
{edited to post this link} http://tinyurl.com/3yfks2
Does anyone else have experiences they are willing to post regarding aftermarket rods for the S4 block?
Are there any more choices?
Any other insights when chosing rods greatfully recieved!
Spen
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
MarkB
Re: Rods.
Post by MarkB » Thu Nov 22, 2007 3:57 pm
Post the link! :)
Mark
JonnyX
RE: Re: Rods.
Post by JonnyX » Thu Nov 22, 2007 4:09 pm
Do carillo do rods for the rs4/s4?
I think MRC do some but they might be Dahlback. Not sure.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
rikrose
RE: Re: Rods.
Post by rikrose » Thu Nov 22, 2007 5:14 pm
Yow. Pauter do titanium rods. Just in case you have too much money.
Goodwood green RS4, previously owned by jeffw
musty1
RE: Re: Rods.
Post by musty1 » Thu Nov 22, 2007 5:42 pm
I spoke to Nick at arrow a few months back it seemed the s4 rods they listed were wrong so I sent a rs4 and s4 rod to them to take measurements and produce some nether heard from them again, 034 motorsport do a set $1050 also got Eurospec, Carrillo do rods but very expensive I think around the £1600 mark also another company called SCAT do rods for $600 but don’t know anybody that has used them
1.9TDI A6 are sh*t wrong forum
saf
Re: RE: Re: Rods.
Post by saf » Thu Nov 22, 2007 5:47 pm
musty1 wrote:I spoke to Nick at arrow a few months back it seemed the s4 rods they listed were wrong so I sent a rs4 and s4 rod to them to take measurements and produce some nether heard from them again, 034 motorsport do a set $1050 also got Eurospec, Carrillo do rods but very expensive I think around the £1600 mark also another company called SCAT do rods for $600 but don’t know anybody that has used them
With a name like SCAT, Id be banking on them being <beep>! :dung:
musty1
RE: Re: RE: Re: Rods.
Post by musty1 » Thu Nov 22, 2007 5:54 pm
Well you would think so by the price but they seem to do alot for yanks mussel cars which have alot of torque. the thing is you save a little on the price ot the rods but it could cost you more if they fail is it worth the risk
dummi
Post by dummi » Thu Nov 22, 2007 6:31 pm
don't like those pauter's, standard i-beam looks better, but i go for h-beam they're heavier but they are strong. i heard good things about scat in 1.8t's too
spen
Post by spen » Thu Nov 22, 2007 9:00 pm
Thanks guys. More names to research. Dummi- why are you down on the pauter's? Hard to call something on looks alone? (though I feel they look heavy, but I don't know it)
Anyone know the weights of the standard rods?
I'm with musty1 of the quality of the rotating assembly - a poor exhaust just breaks. poor rods break everything!
mikeyquattro
Re: RE: Re: Rods.
Post by mikeyquattro » Thu Nov 22, 2007 9:42 pm
Scat products used quite alot in the aircooled VW world. Sub 10sec 1/4 beetles aren't the sort of <beep> you might be into saf :wink:
Tomorrow is another day
quattronutter
Post by quattronutter » Thu Nov 22, 2007 9:48 pm
rate the scats fairly high,lots of high power cars running with them,like mikeyquattro said used in lots of aircooled engines with monster power
dummi
Post by dummi » Thu Nov 22, 2007 10:18 pm
its just the structure of the rod i don't like i'm more confident in I or H beam. pauter used to do I beams which had good results and light weight so i don't imagine them making a bad product the X design is not structural as robust as an I beam . though i can see what they are trying to do by reinforcing the weak points at the main and gudgeon with the the meat of the rod and even size through out. i just imagine the same material in a I or H beam being stronger, but they may have done some other design tricks to it. thats just my thoughts as its the first time i've seen them
DavidT
Post by DavidT » Thu Nov 22, 2007 10:54 pm
Guys, I'm moving this to tuning & mods so everyone can benefit from the content :)
musty1
Re: RE: Re: RE: Re: Rods.
Post by musty1 » Thu Nov 22, 2007 11:52 pm
dummi wrote:don't like those pauter's, standard i-beam looks better, but i go for h-beam they're heavier but they are strong. i heard good things about scat in 1.8t's too
The 9 sec s4 in poland uses pauter rods he is runing iirc 1000bhp with nos and high reving engine
maybe scat is worth looking into a bit more, I mean £300-£400 for a set of forged rods thats a great price
okkim
RE: Re: RE: Re: RE: Re: Rods.
Post by okkim » Fri Nov 23, 2007 9:50 am
I am using Auto Verdi rods, they promised 1000 HP and 9000 RPM's "no problem". Those were expensive, but the quality is very good! Rods have also the best ARP bolts.
I had SPMrods, but the big end outer diameter was 83 mm, so it was impossible to install to 81.5 mm bore.
Users browsing this forum: No registered users and 15 guests
