Wipers linkage p/n
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Dippy
Wipers linkage p/n
Post by Dippy » Tue Nov 13, 2007 8:55 pm
I have the slow wipers problem, so I just got my replacement part from VAGparts. I looked up the part on a web-based ETKA and got 8D2 955 603B. However seeing that one of the other part numbers I found was out of date, now I'm worried if I got this one right. Can anyone confirm?
2001 Silver S4 Avant
s4woody
RE: Wipers linkage p/n
Post by s4woody » Tue Nov 13, 2007 9:29 pm
that part number is to a base windsheild wiper..is that the part you wanted..
GARTH ROAD MOT CENTRE LTD
020 83353032
philipwalker
Post by philipwalker » Wed Nov 14, 2007 9:23 am
The part number you have is correct for a RHD car maybe the part number has changed.
You only need to strip and grease the wiper spindles, carefull not to loose the small circlips on top or the spindle arms.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
Dippy
Post by Dippy » Sun Nov 18, 2007 10:51 am
OK, so I replaced my linkage with the new one (8D2 955 603B). The existing one had p/n 8D2 955 023G. The only difference between then seems to be that the new one has different spindle grommit/covers which will give some protection to the area where the circlip is, wheres the old one had gromits which leave this area open to the elements.
My problem was the classic case = the drivers side spindle was corroded solid. I am glad I bought the new assembly because it looked really bad.
I spent at least an hour just trying to remove the assembly (yes with the ECU cover off), but no matter how hard I tried, I couldn't do it. So in the end I unbolted the motor in situ and was then able to extract both parts easily.
Put it all back and fitted new aero wipers - now waiting to see if they're as good as all the reports suggest.
aikihook
Post by aikihook » Sun Nov 18, 2007 8:15 pm
I just fitter aeros - but I found that the drivers wipe stops 2" away from window edge. I didn't notice before I changed them - can the stop position be adjusted?
S4 - Silver 2000
philipwalker
Post by philipwalker » Sun Nov 18, 2007 10:37 pm
You did it the hard way !
Remove the ecu housing top and bottom.
PW Motorsport
01437 563929
