How to calibrate MPG display after bigger injectors?
CliveH
Post by CliveH » Sat Nov 03, 2007 7:58 pm
This question remains unresolved from a previous thread (which should probably have been moved to the VAG-COM section)
http://www.rs246.com/index.php?name=PNp ... ic&t=65560
viperbl and I have MPG differences (actual vs DIS) which, if we made adjustments using the adaptation function (channel 3), would go off the end of the scale (permitted range 85 to 115). Hence this doesn't work for such large discrepancies (well mine is still about 5% out after entering the lowest value of 85).
Oddly enough, we are at opposite ends of the scale after fitting bigger injectors :shock:
There are posts in the other thread which suggest that the adaptation is just for minor calibration, whereas there is a more fundamental setting to change, which takes account of the larger injectors.
It seems that this may be one for Uwe or Sebastian, although it is rumoured that Mihnea may also hold the key... :sekret:
Clive
S2tuner
Trader (Expired)
RE: How to calibrate MPG display after bigger injectors?
Post by S2tuner » Sat Nov 03, 2007 10:48 pm
Clive, give us a shout and next time you see me or Doug you'll get an updated file. The MPG is adjusted on all our files but sometimes it's still off... :(
Sebastian
Post by Sebastian » Sun Nov 04, 2007 12:08 am
Agreed, like S2tuner said in terms of mods like yours the best option is to talk to your tuner. The instrument cluster just deals with what the ECU tells it and that should be somehow within a reasonable range, otherwise an adjustment is not possible.
Sebastian @ Ross-Tech.com
CliveH
Post by CliveH » Sun Nov 04, 2007 12:51 am
Thanks guys :thumbs:
Be seeing you soon Mihnea... :wink:
Clive
viperbl
Post by viperbl » Mon Nov 05, 2007 2:31 pm
Good man Mihnea :)
I put mine to the max the adaptive channel well go and got to within just under 3MPG difference ... close, but no cigar
RS4 B5 Saloon8) with 750+ bhp :D
Chubby
Re: RE: How to calibrate MPG display after bigger injectors?
Post by Chubby » Thu Jan 10, 2008 9:11 am
viperbl wrote:I put mine to the max the adaptive channel well go and got to within just under 3MPG difference
Ditto ..
Its a pain but it's good to find out it can be resolved...
R.
RS4 Misano Red (The Fast Colour) - A Few Extras = 550bhp - In Love Again - Now broken - Hate the Bitch... Has to go...
GT-R arriving 14/05/09 - Too many toys - not enough time...
Return to “DTC / VCDS”
