Changing sidelights HELP!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
mattfinn
Post by mattfinn » Thu Oct 25, 2007 9:17 am
I am completely stuck as to how to get to the little devils, I have one side out and want to replace both with some fancy blue Philips jobbies.
I can see how to get to the Xenon's, but there is a yellow electric shock warning sign that is putting me off some serious tinkering.
Do I need to remove the whole headlight unit? If so which bolts do I take off.
Pics would be nice, I am lost and have searched the forum and web to no avail.
Thanks,
Matt
Jarv
Post by Jarv » Thu Oct 25, 2007 9:30 am
Not sure if they are the same as the RS4, but if they are, then this threed may help:
http://www.rs246.com/index.php?name=PNp ... hlight=led
I replaced mine, it's pretty fiddly, but it is possible to do it without taking the headlights out.
Are you sure you want to put blue bulbs in though? I went for white LED's as per the thread above, IMHO I think they look better than the yellowy original one's.
HTH.
Mike
Q7
Blue_Thunder
Post by Blue_Thunder » Thu Oct 25, 2007 6:39 pm
I had a set of the blue Philips bulbs fitted (too much of a PITA for me!).
They look much better than stock and appear brighter.
Nige_RS4
Post by Nige_RS4 » Thu Oct 25, 2007 6:55 pm
You can remove the cover from the zenons to give you more room, but make sure they are off and no metal comes into contact with them back of them (I'm not sure if they hold any charge, but better safe than sorry).
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
mattfinn
Post by mattfinn » Thu Oct 25, 2007 8:03 pm
Cheers guys, im set on the blues for now. Managed to get the bulbs out of the headlight casing, just couldnt get the little sods out of the carriers!! Didnt help I attempted it on my dinner break, over a hot engine with a stress on anyway!!
Gonna have a crack in the morning over a cold engine and a fresh temper lol!
imolas4uk
Post by imolas4uk » Thu Oct 25, 2007 9:59 pm
taking out the headlight makes it dead easy 4 torx 30's hold it in loosen the rear two then take the upper bolts out completeley,the headlight will then slide forward without even dissconnecting the wiring.
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
shineydave
Post by shineydave » Fri Oct 26, 2007 9:54 am
you might want to get a piece of rubber or nylon pipe with an internal diameter slightly less than the diameter of the bulb. you can use it to grip the bulb so you can twist it out of the bayonet fitting
hardhitter
Post by hardhitter » Fri Oct 26, 2007 12:04 pm
Are they a push fit (W5W) or bayonet type fitting (T4W) ?
am8631
Post by am8631 » Fri Oct 26, 2007 1:29 pm
they are push fit on preface lift models - and bayonet on facelifts. I know this because after much skin slashing to get the bulb out i found i had the push fit ones when i ordered the bayonet type :(
Matt_H
Post by Matt_H » Fri Oct 26, 2007 9:24 pm
imolas4uk wrote:taking out the headlight makes it dead easy 4 torx 30's hold it in loosen the rear two then take the upper bolts out completeley,the headlight will then slide forward without even dissconnecting the wiring.
Arrrrrrghhh - I just tried this, took out all the torx bolts and whilst the headlight was loose, it aint going anywhere - what am I doing wrong :x
HennessyXO
Post by HennessyXO » Fri Oct 26, 2007 11:50 pm
Bollocks!
I received today; two bayonet type sidelamps.
I have a pre-facelift.
Bugger.
SJS
Post by SJS » Tue Oct 30, 2007 1:22 am
HennessyXO wrote:Bollocks!
Bugger.
PM sent
Nogaro S4 Yr2000. MRC remap, K04s, Milltek
Matt_H
Post by Matt_H » Tue Oct 30, 2007 9:16 am
Matt_H wrote: Arrrrrrghhh - I just tried this, took out all the torx bolts and whilst the headlight was loose, it aint going anywhere - what am I doing wrong :x
I still can't figure this out, and I lost one of the torx screws down the side of the light and into the engine bay and now can't find it. I'm going to have to take it to a garage to change a bulb.......I'm so embarrassed..... :oops: :? :oops:
Danian
Post by Danian » Tue Oct 30, 2007 2:26 pm
I do the sidelight bulbs on my facelift all the time (dont seem to last longer than 6 months?). It's a piece of piss to do, no headlight removal required, are we saying you cant do this on a pre-facelift and the headlight has to come out?
B5 S4
B8.5 S4
mattfinn
Post by mattfinn » Tue Oct 30, 2007 2:38 pm
Danian wrote:I do the sidelight bulbs on my facelift all the time (dont seem to last longer than 6 months?). It's a piece of piss to do, no headlight removal required, are we saying you cant do this on a pre-facelift and the headlight has to come out?
I believe mine's the same bulbs as you use, except I have bought the wrong ones. How do you remove the bulbs? Any links to bulbs you've bought? Ta
