SAT NAV TV PLUS
SAT NAV TV PLUS
Does anybody know anything about retro fitting a SatNav tv plus system, I have RS4 B5 and want to replace head unit, there are several available on EBAY but does it work ? is it easy to do or is it not worth bothering with ??
RE: SAT NAV TV PLUS
Install the RNS-E. Its a much better unit.
Apparantly theres a guy here that does specialised installs. I think he may be a member of the forum.
Hopefully someone will be along to give you his contact detials.
Re: RE: SAT NAV TV PLUS
Many thanks, it seems a mine field with lots of different ideas
Blue_Thunder
- Top Gear
RE: Re: RE: SAT NAV TV PLUS
I think saf's thinking of CraigyB, but he had a disagreement with the mods so you won't find him on here anymore.
That was the dude.
Fair enough. I didnt know about the disagreements.
- shineydave
depends which existing head unit you have as to how easy the conversion is. if you have the Symphony it's a doddle, anything else is a PITA. there's loads of info on this in the forums, try a search
