Discs & Pads Questions??
W8PMC
Post by W8PMC » Tue Oct 02, 2007 10:57 am
Car is going into the dealers tomorrow for new front Pads & possibly new Discs, as i'm getting vibration through the steering when braking hard, so i think i may have warped the front discs slightly in Germany a few weeks back :o Will ask to see the discs in case it's just uneven pad wear that's causing the vibration as i've no intention of replacing the discs if not needed.
The brake warning lamp has not illuminated yet, but they do look well below 20% life left from a visual glance.
My 3 questions are? roughly what's the dealer cost for supply & fit of new front pads & discs?? & secondly does anyone know the biaise of front/rear braking?? I'd like to know roughly what life span rears will provide in relation to fronts? Lastly, what is the normal lifespan of front & rear pads & front & rear discs??
Cheers in advance.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
rs4v8
RE: Discs & Pads Questions??
Post by rs4v8 » Tue Oct 02, 2007 11:14 am
My fingers are crossed for you chief, hope it's not your discs as that is deffo gonna hurt your wallet.. :thumbsdown:
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
t_urbo
Post by t_urbo » Tue Oct 02, 2007 11:19 am
Disc's do not warp, what actually happens is that a small amount of pad gets left behind on part of the disc and creates an uneven surface hence possible vibration, if you tracked the car then left the handbrake on after then you might get this.
Rear pad wear is down to rear loading.
rs4v8
Post by rs4v8 » Tue Oct 02, 2007 11:23 am
Is that what happens? Hmm, maybe the discs I had on my VR6 golf had build-up then, strange though cos there was no actual build up of different coloured material on them :D They were shaped almost like a pringle though!! :lol:
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
rAudiguy
Post by rAudiguy » Tue Oct 02, 2007 11:41 am
Hi Paul,
my local dealer quoted me £440 inc vat and Labor to fit new disc and pads on the front and £300 inc vat and labor for the rears. wouldn't give me any idea on wear time though as down to driving style.
hope that helps mate
Jim
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
t_urbo
Re: RE: Discs & Pads Questions??
Post by t_urbo » Tue Oct 02, 2007 11:41 am
rs4v8 wrote:Is that what happens? Hmm, maybe the discs I had on my VR6 golf had build-up then, strange though cos there was no actual build up of different coloured material on them :D They were shaped almost like a pringle though!! :lol:
See here;- http://www.stoptech.com/tech_info/wp_wa ... disk.shtml
Then go here;- SPECSAVERS
hertfordshire1
RE: Re: RE: Discs & Pads Questions??
Post by hertfordshire1 » Tue Oct 02, 2007 11:56 am
I killed my discs after going to the ring too.
however i had told the dealer i was going there, so they said wear and tear = i paid.
if they are not aware of the track use, claim normal driving and demand warranty work..
also get the brake fluid checked, mine bolied and was useless with the new discs and pads.
my pads were £300 and the discs £600 ish from memory..
my second set were also shagged after my second ring trip and I am to get these replaced FOC is mentioned above.
Steve
rs4v8
Post by rs4v8 » Tue Oct 02, 2007 12:00 pm
Like I said, couldn't see any different coloured material on the discs but they were definately worn and were definately not as straight as they should have been. :D
See here;- http://www.humourtransplant.com/get_one_now :lol:
DavidT
Post by DavidT » Tue Oct 02, 2007 12:04 pm
If the discs are worn, then its wear & tear, regardless of where the car was used, surely ?
The 'warped discs' debate has been around for ever. They can and do 'warp/bend/whatever term you want to use', no matter what StopTech say on their website. Pick up on the discs is more common than 'warping' in high performance setups though, which the RS4/RS6 setup is.
t_urbo
Post by t_urbo » Tue Oct 02, 2007 12:07 pm
Link not working :cry:
Not alot is straight these days :shock:
rs4v8
Post by rs4v8 » Tue Oct 02, 2007 12:08 pm
Thanks DavidT... :beerchug:
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
t_urbo
Re: RE: Re: RE: Discs & Pads Questions??
Post by t_urbo » Tue Oct 02, 2007 12:12 pm
DavidT wrote:If the discs are worn, then its wear & tear, regardless of where the car was used, surely ?
Stoptech's not the only one.
It seems to me that there are plenty that will say they do warp but then again they would because their trying to sell the bloody things.
rs4v8
Post by rs4v8 » Tue Oct 02, 2007 12:15 pm
t_urbo wrote:
rs4v8 wrote:
t_urbo wrote: See here;- http://www.stoptech.com/tech_info/wp_wa ... disk.shtml
Em, no. read the link properly!! :lol:
t_urbo
Post by t_urbo » Tue Oct 02, 2007 12:19 pm
Surely you can do better!
rs4v8
Post by rs4v8 » Tue Oct 02, 2007 12:25 pm
Probably, but you didn't get it first time and that tells me I don't have to..... :lol:
Sorry chief, just pulling your leg, ok? :lol:
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
Users browsing this forum: Majestic-12 [Bot] and 188 guests
