Max power on OEM heads
Does anybody know how many HP you can get with standard S4 heads?
RE: Max power on OEM heads
500-520HP, you wont see much more than that!
jimbo1234567
- 5th Gear
im watching dougs new project with interest
665 bhp + 586 lbft...
Sounds very good. So I assume this was done with std cams also? What kind of intake mods is required for that kind on power? The reason for asking is if I´d go for example GT2560r turbos would those be an overkill for the stock intake or could ~550hp be achievable with stock heads and cams assuming the exhaust system (and everything else) was done properly?S2tuner wrote:We dynoed a french S4 with stock heads and lots of stuff done around that at 560 crank and 730Nm. more could be done but not sure how much more!!!
I´d like to retain the low end torque as much as possible so wouldn´t want to do the heads/cams.
2001 S4 Avant
