Is there any reason why my cruise control would suddenly stop working while i was driving ??
It did it to me this morning
Cruise Control
RE: Cruise Control
there has been some posts about this in the RS6 section..im sure there was talk about the brake light switch..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
RE: Cruise Control
any faults stored ?
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
RE: Cruise Control
Actually, yeah....
Sunday,02,September,2007,12:01:16:05380
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 8D0 907 551 D
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 05711
Work Shop Code: WSC 00134
2 Faults Found:
17746 - Camshaft Position Sensor (G40): Open or Short to Plus
P1338 - 35-00 - -
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 01: Engine
2 Faults Found:
P1338 - 35-00 - -
RE: Cruise Control
Checking the Ross-Tech Wiki only shows the one DTC for the cruise control fault.
http://wiki.ross-tech.com/index.php/17977/P1569/005481
- gavsteryoung
RE: Cruise Control
Mine does this, its the switch in the indicator stork....
If you can get some electrical contact spray in there it should fix it......
I dont think the first code is anything to do with the cruise.
Sometimes if I slide the slider to the right to accelarate to a faster cruise speed, the cruise will cut out, as its obviously detecting a dodgy connection on the slide switch so cutting the cruise for safty reasons....
Hope that made sence..
regards
Gav
regards
Gav
09 Audi S3 - Sprint Blue
99 Audi S4 - Ming Blue - (Gone but not forgotten)
04 Vauxhall Tigra 1.8 Sport - Antiga Blue (The Mrs Car)
