Remapped...
55JWB
Remapped...
Post by 55JWB » Tue Aug 14, 2007 2:45 pm
For fear of starting another round of fights I thought I would share my results after having my car remapped at MRC last week.. I would have posted in the now deleted MRC thread, but i did not want to get stuck in the middle of what seemed to be a lot of mud slinging...
I should start by saying that my last 3 cars have all been mapped, my 225 TT, my Merc CLK and my M3 all with varying degrees of results/success..
So, I have been looking into a map for this car, I was extremely tempted by the DMS group buy and had I been around (holiday) I probably would have gone, my only reservation being that they were some distance from me and if I ever needed any updates or re-flashes, even back to stock for whatever reason it would be a 5-6 hour round trip..
So for initially practical reasons I started looking for tuners in the midlands.. I spoke to Thorney about the superchips map, Revo about theirs and settled on MRC due to their experience with specifically Audi tuning, the B5 guys know them extremely well and rate their work very highly...
I spoke to Minhea directly discussing how I found the car and without him giving his trade secrets away what the map changes and how it might affect my car... As Minhea was in the country I thought I would drive over and meet him and make a decision once there, they are only around 40 mins from my office...
Before Minhea or I agreed to proceed we hooked up vag-com, looked for any fault codes and went out to do some data logging...
The car was fine, apart from one of the ECU's reporting 'running rich' something I was thinking anyway due to the very black sooting of my tail pipes.. only a minor thing and had only been reported once in the fault codes..
We discovered something from the data logging that I infact have posted about here... I had said that the car seems to really surge at 5.5k revs in non sport mode and that this virtually went when sport on. Minhea was able to confirm that the throttle was only opening to 60% until 5.5k revs and then fully, in sport mode fully open all the time... The only reasonable explanation for this is for Audi to create a bigger difference between sport and non sport modes, it really feels like something is happening when you hit the button...
Anyway I decided to proceed...
At the moment MRC do not have the facility to tune via the OBDII port, this may change in the future... flashing this way is actually more detectable as even with Vagcom you can see how many times the ECU has been flashed and it does not take long for any Audi tech to work out how many audi issued flashes your car should have had and what the clock is showing. Having said this, removing the ECU's is alot more intrusive as they need removing from their security cradle, the 'tamper proof' bolts removed and then opening up the sealed ECU, all of which if need be is very detectible by a tech if the are really looking for it. I will have new tamper proof bolts added this week. Mapping in this way is done "in the back ground" and is far less detectable than a flashed ECU, so I have been told..
We had a couple of problems with one of my ECU's not taking the map cos it was getting too hot, it had to be cooled before it would eventually take.. I was a little stressed at the time, but Minhea had copied my original map and ECU before attempting the remap. Worst case scenario if the ECU died, I would need a new one which would have been cloned to my ECU from the back up Minhea had made.
Anyway all done and back out for data logging and testing.. Its worth stating at this stage that MRC do not have a rolling road to assist with mapping, all of my previous cars were mapped without a rolling road, so I am not too bothered about his... the data logging should highlight any running problems and faults...
Immediately i could tell the difference just pulling away in 1st gear... there was far more urgency in the car, I felt for the first time I was actually controlling the car with my right foot as it was extremely sensitive compared to normal. It sounded different too, far more induction noise than I was used to, this was probably due to the fact that the throttle was now opening all the way...
Rev limiter has been moved to 8,400 (looks more like 8,700 on the clock :shock: ), but vagcom confirming 8,400 and the top end limiter removed. I am very pleased about the extra revs.. I found I kept hitting the rev limiter in 2nd and 3rd all the time, not because i was trying but because the car was still pulling and it still 'sounded/felt' there was more to go.. since the map, I dont seem to go anywhere near where I could take it but just over the previous limit where it feels right to change gear.
So how did the car drive....
It pulls so much more, torque seems to come in from between 3-3.5k revs and there is still a small surge in power at 5.5k revs the overall power delivery s now far smoother and constant... 2nd and 3rd are amazing gears, always were, 4th is now very "torque'y" the car is definitely accelerating more quickly, holding the power well and pulling so much harder.
Not a measure of a map I know, but on my daily commute with brain disengaged I approached, took and exited a roundabout in 6th with no bother as there is heaps more pull in the car...
So far this is all in non-sport mode.. Activate that, the grumble seems a little deeper, probably because of the induction noise.. and it flies... I joined a dual carriageway and floored it and surprised myself how quickly I got to the bottom of the slip road and how bloody fast I was going by the time I got there, I actually hit the brakes as soon as I entered the carriageway!
So having a play is one thing, what about day to day, stuck in traffic driving... first gear is taking a bit of getting used too, i was so used to having to dial up loads of revs for a quick getaway, it just does not need it now, low revs its pulling so well I have been a little jerky.. anyone that has driven an SMG M3 with sport activated will understand what I mean... 2nd is much more manageable... cruising is lovely, I have just taken some elderly clients out for lunch and I was "driving Miss Daisy" very easy to drive very smoothly..
Big question next is MPG... If you are caning this car we know the results.. since the remap I have seen figures on the DIS I have not seen before.. on my 18 mile commute home in rush hour traffic, I hit 27.4mpg where as at best i would previously only get around 25.2mpg
All in all, I am very happy, Its the first time I have had any dealings with MRC, I found them to be very knowledgeable, very informative and friendly.. whilst I was there, there were 3 other forum members there getting things done to their cars, admittedly B5 owners but they have been using them for a long time and only have great things to say about them...
I did not fully know what I could expect from this map, after having the M3 done with very little noticeable performance improvement, apart from the kangarooing from cold completely disappeared, I was not expecting much... I was Very, very wrong... I think that anyone driving my car over stock would immediately tell how much better the performance now is, to me that’s all you could ask for...
Dyno's for these cars as we know is not easy due to the 4wd and in particular the differential between front and rear on these cars... I don’t know what the bhp increase will be, there has to be some because of the way it now drives.. feels like more than 15bhp, I expect less than 30bhp I am really pleased I now don’t feel like I have to 'wind the car up' to achieve peak performance, it now feels like its there under my foot at all times...
There you go, please don’t start any fights and remember I am not a tuner if you start asking questions... I will do what I can...
Jason
P.S. obvious thing I missed £600+VAT :wink:
June 08 S5 ¦ Phantom Black ¦ Black Silk Nappa Interior ¦ Carbon Trim ¦ DVD Nav Plus ¦ DAB Radio ¦ AMI ¦ Phone Prep High ¦ Bang & Olufsen ¦ Parking Plus ¦ Heated Memory Seats ¦ Auto Dipping Rear & Side Electrically Folding Mirrors ¦ Adaptive Xenon's and no Mod's just yet ;)
W8PMC
RE: Remapped...
Post by W8PMC » Tue Aug 14, 2007 3:22 pm
Nice one Jason & a good write-up.
Only point of potential discrepancy is the detectability of OBDII vs physical removal of the ECU. It's plain that if someone wanted to look hard enough, the map could be detected no matter what method, however it's widely claimed that the opposite of the MRC claim is true, that being a removed & re-flashed ecu is MORE detectable than one flashed via OBDII.
This is only what i've heard, however i know many tuners have moved on from physical removal & now go via OBDII.
Your findings are bang on the money & almost to the letter exactly the same on-road gains i've had. Surprising how much of a difference a decent re-map can make, even ignoring the fact the actual gains in figures are probably not that great in %age terms. The extra revs make a huge difference & turn 2nd & 3rd gears into monsters, mated with the fact you now don't have to drop out of 6th or 5th if you need to move quickly, as the power/torque are on tap.
Enjoy & i'm well chuffed for you.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
55JWB
RE: Remapped...
Post by 55JWB » Tue Aug 14, 2007 3:39 pm
I think I would have preffered the OBDII route, its not nice seeing your ECU's being prised open like an old paint tin!! that said, great results and for me good value for money... trouble is I am really tempted now to look for a resonated valved Milltek as Minhea said there could be a little more in the map with one fitted... just not something I can get past the wife anytime soon! ;)
W8PMC
RE: Remapped...
Post by W8PMC » Tue Aug 14, 2007 3:47 pm
Jason, can you clarify the Milltek statement?? Are you saying MRC can extract a little more grunt from their map with just a Milltek cat-back?? I know with the full system (downpipes & sports cats) it's worth getting a map re-done to take full benefit, assuming the emissions are not an issue, but Milltek told me that any re-map will adapt if it notices added breathability by having a cat-back system, therefore no need or extra gains by re-mapping the re-map (if that makes sense?)
Paul
55JWB
RE: Remapped...
Post by 55JWB » Tue Aug 14, 2007 3:51 pm
Would need to ask Minhea what he meant on that one, he offered for me to go back if I have a Milltek for some fine tuning of somekind, the conversation was around Cat back only... he did explain why their map works on de-catted cars, but it was over my head.. :oops:
S4INT
RE: Remapped...
Post by S4INT » Tue Aug 14, 2007 4:02 pm
Great write up Jason - glad you're pleased with the results :thumbs:
I also noticed a big improvement in MPG - I'm now regularly getting well over 300 miles out of a tank, where as it was 280- odd before the remap. Best I've seen was 29.8 mpg on a run round the M25 to High Wycombe!
Enjoy!
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
W8PMC
Re: RE: Remapped...
Post by W8PMC » Tue Aug 14, 2007 5:00 pm
55JWB wrote:Would need to ask Minhea what he meant on that one, he offered for me to go back if I have a Milltek for some fine tuning of somekind, the conversation was around Cat back only... he did explain why their map works on de-catted cars, but it was over my head.. :oops:
Cheers, Varsity & MRC posted something about the de-cat re-map, as they're meant to be the only company currently able to offer a specific re-map for de-cat B7 RS4's, which makes sense.
Let me know about the Cat-Back scenario, as Milltek have confirmed no fine tuning is required & both stock ECU's & re-mapped ECU's will pick up the slight variances involved on B7 RS4's with Milltek cat-back systems.
Paul
55JWB
Re: RE: Remapped...
Post by 55JWB » Tue Aug 14, 2007 6:13 pm
W8PMC wrote: Let me know about the Cat-Back scenario, as Milltek have confirmed no fine tuning is required & both stock ECU's & re-mapped ECU's will pick up the slight variances involved on B7 RS4's with Milltek cat-back systems.
I got the impression that nothing was "required" with the addition of a Milltek, but if there was one present then the map could be 'advanced' further to take full advantage, obviously even with maps there are still some tolerances, I would want to know how far I was 'pushing' the car before I agreed to something..
We all know if longevity is not an issue the maps can be pushed way out there, its a balancing act... I would ere on the side of caution, I am really happy with the results and would only really think of the cat back Milltek as a looks and sound thing with negilible performance gains... the way I understand it, most maps will work better with a better flowing exhaust so as a result you are getting 'more out of the map' regardless of who's it is...
Jason
VARSITY
RE: Re: RE: Remapped...
Post by VARSITY » Tue Aug 14, 2007 6:14 pm
Respectfully placed smiley coming up......... :mrgreen: so not to offend anyone.
I know Miltek have sports cats but are they making de-cats as yet?
On the original posting on the group buy for our friends in S'ton wasn't there something regarding a Miltek equipt car that had problems running lean and hot due to the re-map and lack of cats? Maybe my memory serves me wrong.
And before anyone kicks in, I am being serious.
Never argue with an idiot, they will drag you down to their level and beat you with experience.
VARSITY
Post by VARSITY » Tue Aug 14, 2007 6:17 pm
Umm,
What I mean is I don't want to be in that place, the car with Miltek and remap is awesome comparred to standard.
Ads4
Post by Ads4 » Tue Aug 14, 2007 6:36 pm
Pleased you got it sorted Jason and that it was worth the wait! :wink: Was nice to meet you mate... :beerchug:
Adam.
MRC B5 S4 Avant.
t_urbo
Post by t_urbo » Tue Aug 14, 2007 6:45 pm
Great info and an excellent write up Jason.
Data logging is an excellent way to tune, and seems like you got a good price for the effort MRC put into it.
t_urbo
Re: RE: Re: RE: Remapped...
Post by t_urbo » Tue Aug 14, 2007 6:53 pm
VARSITY wrote:Respectfully placed smiley coming up......... :mrgreen: so not to offend anyone.
The Miltek car was running lean before the ecu flash and after. It was only slightly on the lean side.Nothing to do with DMS
confusionhunter
Post by confusionhunter » Tue Aug 14, 2007 6:57 pm
Brill write up, thanks for taking the time to do so.
Mark.
s4woody
Post by s4woody » Tue Aug 14, 2007 7:06 pm
DNA tuning can map a B7 RS4 to run with or without cat's...ive been to see JR about doing my M5 and he was talking to a guy about doing his RS4..
GARTH ROAD MOT CENTRE LTD
020 83353032
Users browsing this forum: Bing [Bot] and 181 guests
