Only 8 hours to go
pippyrips
Only 8 hours to go
Post by pippyrips » Tue Aug 07, 2007 10:38 pm
before i leave to pick up my RS4 :D :D :D Got a nice 3 hour drive home to get acquainted 8)
mip
Re: Only 8 hours to go
Post by mip » Tue Aug 07, 2007 10:52 pm
pippyrips wrote:before i leave to pick up my RS4 :D :D :D Got a nice 3 hour drive home to get acquainted 8)
You will love it...
I am still in my honeymoon period with mine as well :-)
What did you get ?
MIP
Mugello Blue RS4 Saloon
simple1
RE: Re: Only 8 hours to go
Post by simple1 » Wed Aug 08, 2007 7:21 am
Just watch the speed cameras outside Swansea!!!! Have a blast!
audijohn
Post by audijohn » Wed Aug 08, 2007 7:41 am
This is 3 hours of bliss coming up, remember RUN it IN.
best of luck today. :twisted:
W8PMC
Post by W8PMC » Wed Aug 08, 2007 7:54 am
Feck the running in, just be gentle until the "max 7K RPM" leaves the display & then cane it.
Enjoy as i know you will.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
djcevo
Re: RE: Re: Only 8 hours to go
Post by djcevo » Wed Aug 08, 2007 9:06 am
W8PMC wrote:Feck the running in, just be gentle until the "max 7K RPM" leaves the display & then cane it.
Definately agree!! You will then get the engine running it's max power quicker (FACT)
crafty1
Post by crafty1 » Wed Aug 08, 2007 9:30 am
had mine since saturday and can confirm you are in for a treat, took it out in the wet last night first time and was amazed how much grip it has and how effortlessly it puts the power down, as an all rounder in all weathers at this price level it has no equal, and that engine.... you wont forget the 1st time you go for 8,250... :shock:
enjoy
reevesroadster
RE: Re: RE: Re: Only 8 hours to go
Post by reevesroadster » Wed Aug 08, 2007 9:31 am
Agree with the above comments entirely. Runs much better when driven hard (once warmed up) and is much more fun too :-)
Everyone is unique, just like you and me.
mip
Post by mip » Wed Aug 08, 2007 6:55 pm
Just a question, does that include full throttle?
The book says drive upto 7000 but avoid full throttle....
MIP
W8PMC
Re: RE: Re: RE: Re: Only 8 hours to go
Post by W8PMC » Wed Aug 08, 2007 7:04 pm
mip wrote:Just a question, does that include full throttle?
I think the book says constant full throttle i.e. always bouncing it off the limiter. A quick nudge of 8000 RPM once fully warmed up will do no harm.
All new RS4's do about 50miles before they leave Quattro GmbH as they are tested fully & i was told that all Audi engines are pretty much pre-run in & designed not to need a long run-in procedure (unlike the E60 M5 which runs special oil for the 1st 1900 miles & the revs are electronically limited until the car hits over 2000 miles :cry: ).
The only thing to stick to is the warm up, so wait until the "max 7000RPM" vanishes from the display & you'll be fine.
Saying that, i've by accident bounced off the 7K RPM limiter about 3 times when i assumed the car was warmed up but the display had not yet switched to oil temp :oops:
Paul
alex_123_fra
Post by alex_123_fra » Wed Aug 08, 2007 9:58 pm
Hi Paul,
Haven't done this yet but I can see how one can feel the car has been running long enough to be warm, yet isn't.
Is there an actual 7,000 rpm limiter prior to the oil temp being optimal? I seem to remember reading the manual a while back which (IIRC) said that the 7k rpm sign is only to warn the driver rather than a physical restraint. Someone else mentioned it too...can't remember who.
Don't really have the balls to try it out. Would be good if it is a proper 7k rpm cut off as that would prevent excessive wear I guess.
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
richardofthesun
Post by richardofthesun » Wed Aug 08, 2007 10:46 pm
Cold running (before oil temp display) certaintly has a reduced rev limited range. Got caugt pulling out out of a junnction and was watching revs for 8 k in 1st, only to here bop, bop, bop at 7 k
W8PMC
Post by W8PMC » Thu Aug 09, 2007 8:19 am
Hi Paul,
It's certainly their & bang on 7K RPM. I've never done this on purpose, just as above when i thought the engine was warmed up but i was perhaps a few minutes early & bounced off the 7K limiter.
Truth be known & it's fairly funny, when i had the re-map re-done at the Group Buy day, i warmed the car up a little & then went for a balls out test drive, only to bounce of the 7K limiter so was all set to moan as i'd been advised the limiter was actually lifted to 8400 as part of the re-map. Only to realise it was the lower limiter i bounced off briefly :oops: All was well once the oil temp was over 60 degrees :D
Paul
pippyrips
RE: Re: RE: Re: RE: Re: Only 8 hours to go
Post by pippyrips » Thu Aug 09, 2007 3:18 pm
Well I am now a fully fledged member of the community :D
I was really surprised at how good it was on petrol on the way back as well. Coming from a 370/370 JDM Impreza I am used to poor fuel economy though the RS4 is definitely better (at least on M-ways).
The build comfort and ride quality is also very good and the 3 hours went in what seemed like 5 minutes.
The car is fully loaded minus phone prep. so this is the next thing to do. Am I better off fitting a Parrott or getting Audi to add on the Bluetooth phone install?
Best bits so far are the bucket seats and simply starting the car up in S mode - the sound is to die for :)
All i need to do know now is find time to read the rather large manuals to learn how to use everything!
LegalEagle
Re: RE: Re: RE: Re: RE: Re: Only 8 hours to go
Post by LegalEagle » Thu Aug 09, 2007 4:07 pm
pippyrips wrote:The car is fully loaded minus phone prep. so this is the next thing to do. Am I better off fitting a Parrott or getting Audi to add on the Bluetooth phone install?
One word, one man: Craigyb
You'll find him on here by doing a search.
LE
Users browsing this forum: No registered users and 204 guests
