Misfire cylinder 4 ???
2.7 V6 30v biturbo - 380 bhp
mattykerby01
Post by mattykerby01 » Tue Aug 07, 2007 1:40 pm
Hi,
Have the following fault codes when driving the car hard - can anyone shed any light for me?
Car has just been serviced with new plugs.
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
Coil packs maybe? Where is cylinder 4?
Matt
TopBear
Post by TopBear » Tue Aug 07, 2007 4:19 pm
How did you get those codes, i.e. have you got VAG-COM?
You could try resetting the DTC codes, and then measuring the blocks 14+15 to see at what revs the misfires occur.....alternatively give MRC a call, and ask Doug or Minhea what can cause this, however from memory it could be either of the following......
a) Coil pack
b) Spark plug
c) Defective Injector
d) Crack in cyclinder head
e) Worn camshaft lobe\follower
Mines was option e :cry:
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
mattykerby01
Post by mattykerby01 » Tue Aug 07, 2007 5:14 pm
Many thank for that - any idea which one is cylinder 4 - i am going to swap this with another coil pack and see if the problem follows.
Ta!
Norrs2
Re: Misfire cylinder 4 ???
Post by Norrs2 » Wed Aug 08, 2007 7:08 am
mattykerby01 wrote: Car has just been serviced with new plugs.
Matt
Although my car appeared to be running ok, when getting a MRC re-map they did a health check and found a random missfire. It just turned out to be loose plugs on both centre cylinders. A common fault according to Doug, by dealers who don't tighten them properly. Where did you get the car serviced? It may be just that simple!!!
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
grizz
RE: Re: Misfire cylinder 4 ???
Post by grizz » Wed Aug 08, 2007 7:22 am
Matt ,
P0300 - 35-00 - -
P0304 - 35-00 - -
I've had these on several cars when the MAF is on it's was out .
Unit 20
0151 3366888
derdle
Post by derdle » Wed Aug 08, 2007 9:35 am
I had exactly the set of faults (on cylinder 6 though) .... cured by Doug (of course). Great expense...he tightened the spark plugs!
My suggestion is to go round all 6 plugs and re-tighten them, clear the fault codes and then drive the car for a while and re-test with Vag-com.
Paul
neily
Post by neily » Wed Aug 08, 2007 10:04 am
this is spooky.....
Doug had to retighten mine last week whilst he was going a few other bits and pieces for me....
2001 RS4 Avant - thats been touched by the MRC magic wand.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008
Harper--D
Post by Harper--D » Sat Aug 11, 2007 11:19 pm
"spooky"? Sounds like Audi has fvcked up again!!!
Dave.
White MK2 Golf.. Slightly modified :D
dr.sah
Post by dr.sah » Sat Apr 25, 2009 8:08 pm
EXHAUST CAM IS DAMAGED.
rtd
Re: RE: Re: Misfire cylinder 4 ???
Post by rtd » Sun Apr 26, 2009 11:01 am
dr.sah wrote:EXHAUST CAM IS DAMAGED.
thats a really helpful comment - NOT.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Contigo
RE: Re: RE: Re: Misfire cylinder 4 ???
Post by Contigo » Sun Apr 26, 2009 11:27 am
I'm guessing that sah has recently had cam issues and he's seen this vag code from this here thread and thinks it's the same.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
