What's the torque split bet. F/R on the RS4 B5?
2.7 V6 30v biturbo - 380 bhp
surfpilot
Post by surfpilot » Fri Jul 27, 2007 12:11 pm
What's the torque split between the Front/Rear on the RS4 B5?
Would a Torsen Diff upgrade like the link below work?
http://www.stasisengineering.com/Catego ... N=8&PID=98
Inputs please!
Thanks,
Manny
dodgydave
RE: What
Post by dodgydave » Fri Jul 27, 2007 12:27 pm
2:1. The stasis text is misleading!!!
S4 and RS4 have both 2:1, which means it can shift a max of 66% to front or rear.
I went for the Stasis upgrade to 4:1, which shifts up to 80% to front or rear.
PLEASE, don't confuse this with the 40:60 split on the new RS4 or R8 where in fact there will always be more power send to the rear wheels no matter what the grip. This will give you a more rear wheel drive car experince and reduce the agressive oversteer our car normally suffer from.
So, I ugraded to 4:1 and put a torque sensing quaife diff in front and back. The quaifes actually will send the power to the wheel with the most grip not the once, which hang in the air as on your standard diff. So, you will keep having traction especially if you accelerate out of corners on bumpy roads.
Car will be on the road in the next 2 weeks I'll let you know how the feel is now.
DavidT
RE: What
Post by DavidT » Fri Jul 27, 2007 12:36 pm
Welcome to the site.
Torque split is 50:50.
Bias is 4:1 so there is no benefit in adding the Stasis torsen to a B5 RS4 so far as I can see.
dodgydave
Re: RE: What
Post by dodgydave » Fri Jul 27, 2007 12:50 pm
DavidT wrote:Welcome to the site.
Well,
I also found a lot of info saying the RS4 has a 4:1 split but couldn't find any official document supporting it. Also the S4 and RS4 torsen have the same part no. It seems the 4:1 info might be an urban myth.
Im still toying with the idea of fitting the B7 diff. By the looks of it I'm pretty sure with a few mods it would fit ) 01E boxes.
Anyone got a B7 box where I could have a look to confirm this ? ;o)
DavidT
RE: Re: RE: What
Post by DavidT » Fri Jul 27, 2007 1:07 pm
Thats interesting, thanks Dave.
Also, Stasis were advertising a rear biased torsen with 40f/60r torque split a while back with the same 4:1 Bias for the B5 cars. It seems to have been removed now, I would have tried one of those :(
surfpilot
RE: Re: RE: What
Post by surfpilot » Tue Jul 31, 2007 12:03 am
Thanks for the info guys! I really appreciate it :)
kies4
RE: Re: RE: What
Post by kies4 » Tue Jul 31, 2007 1:39 pm
did we get to the bottom of thei is there any benefit fiting the centre diff and rear diff from an rs4 to a s4 ? I got the whole RS4 drive train in the garage and want to know if its worth fitting
S4 Crazy Horse. Ringsticker & MRC black magic.
dodgydave
Re: RE: Re: RE: What
Post by dodgydave » Tue Jul 31, 2007 4:31 pm
kies4 wrote:did we get to the bottom of thei is there any benefit fiting the centre diff and rear diff from an rs4 to a s4 ? I got the whole RS4 drive train in the garage and want to know if its worth fitting
All the diffs between S4 and RS4 are indentical!
smurfbus
RE: Re: RE: Re: RE: What
Post by smurfbus » Wed Aug 01, 2007 11:47 am
I dont get it why that info has not popped out and been talked out before. I tried to ask this question in AW last year in a thread that stasis stuff was in but they did not bother to answer my question. If the part # is the same it would mean 1:4 is a urban myth but etka might be wrong too!
smurfbus
Post by smurfbus » Thu Aug 02, 2007 5:49 pm
ETKA7 also claims that rs4 3rd gear is the same as in S4 2001-2005!
01E311285F
SnowTrooper
Post by SnowTrooper » Sat Aug 04, 2007 1:20 am
Most of the B5 RS4 cernter diffs are in fact a different bias than the S4, but as we all know VAG isn't afraid to parts bin swap. You will notice a difference by going to a STaSIS rear diff unless you are one of the rare and lucky few who got a higher bias diff from the factory.
Jared
Jared @ STaSIS Engineering
2000 s4- two turbos, quattro, lots of kevlar, CF and aluminum, slicks, a welded rear diff, weird paint and about 700 hp
1990 CQ- Bone stock, racks, studded tires = ski car
blackb1ade
Post by blackb1ade » Mon Aug 06, 2007 9:54 pm
You meant 'understeer' right Dave?
Avus B5 RS4 with St.3 MTM
viperbl
Post by viperbl » Fri Aug 31, 2007 3:51 pm
Dave, I know it might be hard to judge with all the rest of your "upgrades"!! but do you recommend the stasis torsen diff??
So, we are all happy that it is normally a 2:1 diff for B5 S4/RS4 unless, as some point, they stuck some 4:1 diffs out? That right snowtrooper? Any idea how to confirm what one we have snowtrooper?
Mine needs replacing anyway, so think I may as well go Stasis, I mean, for the price of around £280 + Postage, it does not seem bad.
RS4 B5 Saloon8) with 750+ bhp :D
smurfbus
Post by smurfbus » Fri Aug 31, 2007 5:51 pm
+CORE IIRC. Somehow I think my RS4 trans has the 4:1 torsen. It doesn't spin the fronts as much and its pretty tailhappy.
SnowTrooper
Post by SnowTrooper » Tue Sep 04, 2007 5:09 pm
The bad thing is that there is no way to really tell other than if you know how it should feel when driving or if you pull it out and inspect it.
