MAF life pole
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
how many miles has your MAF done since the last one
less than 20k
2
17%
20 - 40k
3
25%
40 - 60k
4
33%
60 - 80k
1
8%
80 - 100k
1
8%
> 100k
1
8%
Total votes: 12
buzzard
MAF life pole
Post by buzzard » Thu Jul 26, 2007 5:03 pm
my first MAF lasted about 40K but my second seems like its on the way at 63K
interested to know average age
AdamS4
RE: MAF life pole
Post by AdamS4 » Thu Jul 26, 2007 5:16 pm
I've only had the car for 2 weeks and i've just replace my 1st one which got to 84k....
DavidT
RE: MAF life pole
Post by DavidT » Thu Jul 26, 2007 5:22 pm
Yes, mine got to 65k before the readings started to fall off.
Blue_Thunder
RE: MAF life pole
Post by Blue_Thunder » Thu Jul 26, 2007 5:57 pm
Think we need another option for >40k.
Might also be worth posting what sort of filter people have been using to see how much truth their is in "oiled filters cause MAF's to die early".
S4TAN
RE: MAF life pole
Post by S4TAN » Thu Jul 26, 2007 7:31 pm
Good call Scot - I've used K&N, Green, and now running an ITG (best by far!) - all oiled, none of them have killed a MAF - the only way I killed a MAF was by being a total tool and cleaning the element directly with a cotton-bud soaked in IPA [don't try this at home kids - your MAF will die!] - best way to clean the element is in a bag of IPA and give it a good "slooshing" then leave to soak for 1/2 hour ...
Deus ex machina
MCB
RE: MAF life pole
Post by MCB » Fri Jul 27, 2007 1:36 am
The original MAF died at approx 60K.
S4B5 Avant
GrahamS4
RE: MAF life pole
Post by GrahamS4 » Fri Jul 27, 2007 8:10 am
My MAF was faulty at 29K, but ~ 7/8 years old.
ChipHazzard
RE: MAF life pole
Post by ChipHazzard » Fri Jul 27, 2007 8:51 am
I had my maf changed last yearat approx 85k, I dont know if it was the original maf or not, I have done approx 10k since then
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
C-24
RE: MAF life pole
Post by C-24 » Fri Jul 27, 2007 10:34 am
My MAF is not working properly (it's peak reading is about 180g/s instead of 250g/s) and the car is in limp mode when MAF is plugged in.
When I plug the MAF out, the car runs fantastic performance, but the dashboard shows the ABS and ESP symbols, does that mean that they do not work while the MAF is plugged out ?
Also, is it useful to have a bad-working MAF (ie : lower turbo pressure = better turbo reliability ?) and can I use my car without it with no problem ? Should I replaced it with a new one ?
Thanks a lot.
S4 avant imola yellow
Sportec remap 320hp / 500nm
Brembo GT-brakes
RS4 suspensions
ChipHazzard
RE: MAF life pole
Post by ChipHazzard » Fri Jul 27, 2007 10:44 am
C-24,
IIRC If the maf is bad then it cause's the car to run lean which means increased temp's which in turn burns out the EGT & possibly lamda sensor's, also higher temps could potentially fry the turbo's
In short get a new MAF
FL Noggy S4 Avant
C-24
RE: MAF life pole
Post by C-24 » Fri Jul 27, 2007 11:04 am
Ok but when I unplug the MAF everything seems to be alright, but I noticed huge temperature when I was driving in Slovenia and in Croatia where extern temperature was 40degree Celcius. The car never had more than 90degree, and here with very high extern temperature it gets 100degree, even 115degree once. And Oil temp is about 120degree or 125 when really hot.
A new MAF may resolve this ?
PS : with or without the MAF the motor and oil temps are rising.
Brembo GT-brakes
RS4 suspensions
ChipHazzard
RE: MAF life pole
Post by ChipHazzard » Fri Jul 27, 2007 11:16 am
The car reverts to a default fuel mapping when you unplug the MAF. I'm sure someone else will be along properly to advise accordingly or correct me if I'm wrong
FL Noggy S4 Avant
C-24
RE: MAF life pole
Post by C-24 » Fri Jul 27, 2007 11:18 am
You are right, when unplugged, the chip acts on its own (as it was mapped). But is it bad ?
edit : I mean, why don't we all unplugg our MAF to be sure the car runs full power then ?
Brembo GT-brakes
RS4 suspensions
S4TAN
RE: MAF life pole
Post by S4TAN » Fri Jul 27, 2007 11:36 am
Without the MAF working I don't think the car can adapt to the variables and just runs as if a set amount of air was coming in - so you may not get the full potential of the conditions.... or something
Deus ex machina
C-24
RE: MAF life pole
Post by C-24 » Fri Jul 27, 2007 12:10 pm
Ok, gotta put a new one. I like the bad-working MAF I've got right now, because when the technical control (visit for car) want to test the car, they can't push it so hard, they are little f###ers. :-)
Brembo GT-brakes
RS4 suspensions
Users browsing this forum: No registered users and 115 guests
