Hot starting problem
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Jez
Post by Jez » Fri Jun 29, 2007 8:30 am
Morning all :D
I haven't been around much, v busy with my new job and buying a new house etc. I had no idea how stressfull buying a house could be! :shock:
Hope you guys can chip in with some ideas/solutions regarding an occasional hot starting problem with my 2000 S4. Since late last year there has been an occasional hot starting issue. Basically if the car has not fully cooled down after a run and I try to start the car again it will only just fire and requires a blip of the throttle to spring into life. It's almost as if it wants to idle at 300rpm.
A couple of times it's required a second cranking to get it started. This is only occasional, i.e perhaps 1 out of 10 hot starts.
Over past couple of weeks I've noticed the car is particularly jerky when lifting off the gas after a hot start. Pulls well, just 'bucks' when I lift off. After a couple of minutes this clears and it'll idle slightly high - 900 to 1000rpm.
I changed the spark plugs and did an oil change 2000 miles ago. The hot starting problem was apparant before I changed the plugs.
Other than that the car goes well... all a bit odd.
Sorry for the essay. Thanks in advance guys :D
nickb834
RE: Hot starting problem
Post by nickb834 » Fri Jun 29, 2007 12:31 pm
Have a look for the Idle Stabilisation Valve - not sure where this is on the S4, but I heard of something similar on an S2 that was down to the ISV
Wanted: C5 RS6 Avant
Audis are cheaper than women, and when they finally leave they don't take your kids and half your stuff....
although smack either one about and the police turn up ;-)
dodgydave
Re: RE: Hot starting problem
Post by dodgydave » Fri Jun 29, 2007 2:22 pm
nickb834 wrote:Have a look for the Idle Stabilisation Valve - not sure where this is on the S4, but I heard of something similar on an S2 that was down to the ISV
DBW (Drive By Wire) doesn't need or have such a valve!
dodgydave
Re: Hot starting problem
Post by dodgydave » Fri Jun 29, 2007 2:25 pm
Jez wrote:Morning all :D
Sounds like gas building up in you fuel-lines because of the heat. Used to be a big problem on the old 10V Turbos. Something wrong along your tank venting system. I'd guess.
SimonS4MTM
RE: Re: Hot starting problem
Post by SimonS4MTM » Fri Jun 29, 2007 2:43 pm
Maybe a collant temp sensor and running rich
Jez
Post by Jez » Fri Jun 29, 2007 4:12 pm
Thanks for the replies :)
Ever since I've had the car there's been a coolant temp sensor error in VAGCOM reported as intermittent. This remained post after-run pump mod, so must be another temp sensor or the wiring.
I used to have the same issue on one of my old digifart golf GTIs. A quick blip of the throttle round to 5k rpm used to sort it. Cleaning out the ISV, throttle body and idle screw would normally sort the high revving on the golfs, but does the S4 have an ISV (it is DWB btw)?
Will investigate the tank venting and sensors.
yorkie
Post by yorkie » Fri Jun 29, 2007 6:50 pm
Looks like you could have answered your own question, my money would be on the sensor which sits at the back of the block on the left side as you look at the engine from the front. It sends a signal to the temp gauge and the ecu.
kevinw
Post by kevinw » Sat Jun 30, 2007 2:35 pm
mine did exactly the same..... it was the coolant temp sensor. get it changed.
Philws4
Post by Philws4 » Sat Jun 30, 2007 3:06 pm
IMHO this is a part that should be changed on any S4 that still has the 'older black' sensor still fitted but double check which part/terminal shape you need first as there are 2 that i know of: 059 919 501 & 059 919 501 A
Jez i reckon that you will need the 059 919 501 A sensor,which was the same as mine due to the fact that the car is a 2000 MY.
B5 S4
Philws4
Post by Philws4 » Sat Jun 30, 2007 3:08 pm
B5 S4
Philws4
B5 S4
Jez
Post by Jez » Mon Jul 02, 2007 7:04 pm
Picked up a new sensor this afternoon from the stealers... £27! I haven't changed it over yet, so couldn't comment on the colour of the old sensor, but the new one is green. Finger's crossed, but this could possibly cure that intermittent temp sensor fault in VAGCOM as well as the starting problems :)
Thanks for the input and I'll report back with my findings.
Jez
Philws4
Post by Philws4 » Mon Jul 02, 2007 10:06 pm
Oops sorry about the triple posting!!! :oops:
B5 S4
Jez
Post by Jez » Fri Jul 06, 2007 11:01 pm
Evening all :)
Had a productive afternoon after work and fitted the new temp sensor as well as the DTS I had lying around. The old temp sensor was a git to get out...positively welded in place, but once replaced the car starts as it should when hot and the idle appears smoother too! Time will tell if it's sorted the slight jerkiness.
And for the DTS... marked improvement and compliments the short shifter well. Well worth lying on my back for an hour and a half grazing my hands :)
Cheers all.
mad-for-tar
Post by mad-for-tar » Sat Jul 07, 2007 4:09 pm
I changed the coolant temp sensor on mine the same time I did the after run mod. Coming home from work the odd evening, used to see the coolant temp gauge drop from 80 degrees back to 60 and then slowly climb back to operating temperature. Also noticed a cut in power when I opened the throttle. After changing this sensor, the problem disappeared completely, runs sweet now!
There are 2 tools you need in life: WD-40 and Duct Tape.
If it moves and it should'nt, use the Duct Tape
If it doesn't move and it should, use the WD-40
Users browsing this forum: No registered users and 99 guests
