Sport mode the default
theaxe
Post by theaxe » Fri Jun 08, 2007 2:21 pm
I generally drive in 'Sport' all of the time (love that exhaust note). Is there any way to make that the default so I don't have to press the button at each startup?
55JWB
RE: Sport mode the default
Post by 55JWB » Fri Jun 08, 2007 2:41 pm
Not quite a highjack, but sport mode related, I have been meaning to ask what physically does it do to the car, exhaust and seats if you have them a given... I thought it just shortened the throttle 'throw' but in mine in non-sport I get a definate power surge at 5.5k revs, with sport on, its a smoother power delivery all the way through the range... so as with theaxe, I would prefer to have it on all the time without having to do it, or at least has anyone de-activated the exhaust valves so that they are open all the time??
Jason
June 08 S5 ¦ Phantom Black ¦ Black Silk Nappa Interior ¦ Carbon Trim ¦ DVD Nav Plus ¦ DAB Radio ¦ AMI ¦ Phone Prep High ¦ Bang & Olufsen ¦ Parking Plus ¦ Heated Memory Seats ¦ Auto Dipping Rear & Side Electrically Folding Mirrors ¦ Adaptive Xenon's and no Mod's just yet ;)
WR1Bro
Post by WR1Bro » Fri Jun 08, 2007 2:54 pm
When do you notice the exhaust note change?
We are still running the car in!
W8PMC
Post by W8PMC » Fri Jun 08, 2007 3:03 pm
I heard throttle response, tighten the seats (bit pi$$ed about this one, as i assumed they were active as in the M5, but they just tighten & stay) unless you dis-arm Sports Seats in the DIS & of course the active valves in the zorst.
Tend to hit Sport when playing (showing off) or driving off the motorway, as the extra noise when motorway cruising is a little boomy (only a little).
As per BMW, the Sport button is a bit pointless but i guess giving drivers the option aint a bad thing. I've not noticed any real difference with throttle response between Sport & non-sport, although gear changes are a fraction more jerky in Sport.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
55JWB
Post by 55JWB » Fri Jun 08, 2007 5:26 pm
Paul,
Do you not have the difference in power delivery, in particular the surge at 5.5k revs in non-sport mode that I described??
Jason
Jezzer
Post by Jezzer » Fri Jun 08, 2007 6:47 pm
Will the car use more petrol when cruising on the motorway with sport mode switched on.
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
Chris792
Post by Chris792 » Fri Jun 08, 2007 7:07 pm
I've been wondering about the sport mode to. I'm still just running in, so not really caned it yet, but don't notice a great deal of difference. In my old M3 if you were running along at constant revs and pressed the sport, the speed would increase as the throttle sensitivity adjusted. This doesn't happen in the RS4.
I've got Recaro's so don't have the side bolsters inflate either.
audijohn
Post by audijohn » Fri Jun 08, 2007 8:03 pm
I have not noticed any change in economy with or without the Sport button pressed on constant low throttle.
t_urbo
Re: RE: Sport mode the default
Post by t_urbo » Fri Jun 08, 2007 9:25 pm
55JWB wrote:Not quite a highjack, but sport mode related, I have been meaning to ask what physically does it do to the car, exhaust and seats if you have them a given... I thought it just shortened the throttle 'throw' but in mine in non-sport I get a definate power surge at 5.5k revs, with sport on, its a smoother power delivery all the way through the range... so as with theaxe, I would prefer to have it on all the time without having to do it, or at least has anyone de-activated the exhaust valves so that they are open all the time??
Jason
Opens the Exhaust flaps
Adjusts the seats
Shortens the throttle throw as you mention.
Power surge is the same regardless.
Power delivery is the same.
I tend not to use the sport button as i prefer not to be heard racing up the road and also the throttle becomes too sensitive to be able to drive the car smoothly.
_______________________
07 Model Year RS4
04 996 Turbo S with switchable ecu maps
580 hp on race profile on sunoco GT Plus
550 hp on fast road profile on super unleaded.
07 Model Year RS4
t_urbo
Post by t_urbo » Fri Jun 08, 2007 9:26 pm
Jezzer wrote:Will the car use more petrol when cruising on the motorway with sport mode switched on.
Same fuel consumption. Sport button doesnt alter the power output of the car whatsoever.
07 Model Year RS4
mac4RS
Post by mac4RS » Fri Jun 08, 2007 10:50 pm
I find there is a more up & go around the mid range rev band. Usually use it on the wee roads with twisty bits, keep in third & have lots of fun..........
t_urbo
Post by t_urbo » Sat Jun 09, 2007 9:03 am
mac4RS wrote:I find there is a more up & go around the mid range rev band. Usually use it on the wee roads with twisty bits, keep in third & have lots of fun..........
Imagination is a wonderful thing.
07 Model Year RS4
55JWB
Post by 55JWB » Sat Jun 09, 2007 1:19 pm
I definately have a bit of a surge at 5.5k revs, but no such surge with the sport button depressed... more of a constant pull through the rev range... so should I make a trip to dealer if you guys are not reporting the same effect??
Jason
t_urbo
Post by t_urbo » Sat Jun 09, 2007 4:01 pm
55JWB wrote:I definately have a bit of a surge at 5.5k revs, but no such surge with the sport button depressed... more of a constant pull through the rev range... so should I make a trip to dealer if you guys are not reporting the same effect??
Jason
The sport button has nothing to do with the 'surge' at 5.5k.The 'surge' is the peak torque point of the engine.Do a few test runs on and off, its the same. The exhaust note may be giving you the impression it is going faster with the sport button on.
07 Model Year RS4
Dom81
Post by Dom81 » Sat Jun 09, 2007 8:23 pm
Surely it's just throttle response... Without Sport pushed, you can make small throttle adjustments with little or no change in actual input. With it activated, every minute change in position is delivered straight to the engine.
2007 Daytona RS4 Avant
Users browsing this forum: No registered users and 154 guests
