Indicator fault...relay?
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
stew123
Post by stew123 » Tue May 29, 2007 12:05 pm
Indicators have just packed up on 2001 S3. Bulbs and fuses are okay, indicators either don't work at all or start to flash then stop - this happens on left/right side.
Thinking this is the relay. Anybody else come across this? If so, is this an easy-ish fix as don't want to take to stealers.
Read on other Audi sites that relay is behind/built into hazard switch but not sure on A3/S3.
Thanks in advance!
rsw
RE: Indicator fault...relay?
Post by rsw » Tue May 29, 2007 9:21 pm
this is a common fault on A3/S3/A6/A2/TT models and does require a new relay which is the hazard light switch itelf,easy job pull off the trim around the hazard switch,remove switch fit new job done.
david7m
Post by david7m » Wed May 30, 2007 3:50 pm
Yes, mine went a couple of years ago, about £35 IRC.
APR 270bhp S3, Mixer K6 750
stew123
Post by stew123 » Tue Jun 19, 2007 10:31 pm
Thanks guys. Got relay from dealers. Managed to remove facia trim with improvised hacksaw blade! No damage to trim :)
