which one?
dhali
which one?
Post by dhali » Sun May 27, 2007 2:46 pm
SORRY probably asked a thousand times before :roll: BUT which one do i need? There seems to be some for $249 mark and some for $329-349. My laptop has both usb and com .Have a B5 RS4 (maybe upgrading to B7 in future) and 2003 VW polo.
thnks..
Uwe@Ross-Tech
RE: which one?
Post by Uwe@Ross-Tech » Sun May 27, 2007 4:49 pm
A KEY-Series interface will work for the B5 and the Polo. But if you're thinking of upgrading to a B7, then you'd be better off getting a HEX+CAN now 'cause it will work with all of them. The Micro-CAN interface is not suitable for any of the cars you're contemplating.
USB vs. COM: COM is slightly more better / more elegant for diagnostics. The only reason we make USB interfaces is to accommodate the plethora of new laptops which do not have COM ports. We used to say "If you have a COM port, get a Serial interface" but the question you should ask yourself is: Will your next laptop have a COM port too? Hence if your PC is up to snuff (1 GHz or faster, running Windows XP or newer) USB may be more future-proof.
See also:
http://www.ross-tech.com/vag-com/interfaces.html#choose
-Uwe-
dhali
Post by dhali » Sun May 27, 2007 8:34 pm
thanks for quick reply..
Return to “DTC / VCDS”
