Secondary Air Pump ???
2.7 V6 30v biturbo - 380 bhp
MEV
Post by MEV » Thu May 10, 2007 4:05 pm
Took the ol bus into a stealership earlier this week to check via VAG com a managment light and came back as a possible fault in the Secondary air pump What the hell is that ??? Said it wasnt work and obviously thats initiating other codes to come up. Car is running sweet with no issues I can see elsewhere. Any one help with this and give me a sort of cost to replace as the stealership have quoted a price in italian lire I think :?
B7 RS4 - 07 Phantom, Silver leather, 59k. Current
B5 RS4 - 01 Avus, B7 Brake kit, Miltek cat back, Sroof, leather, optics. 66k. Current
B8 RS4 - Sepang, BO, Roof, Sports Sold
C5 RS6 + # 296 Ebony black, full optics, titans, carbon and natural leather - sold and missed
B7 RS4 Avant Daytona Pearl, black optics, SS+, buckets, privacy. Sold
B5 RS4 - MRC 420. Gone but not forgotten.
dace
RE: Secondary Air Pump ???
Post by dace » Thu May 10, 2007 5:39 pm
Secondary air pump only kicks in on cold start up. It only reduces the emissions for about 2 minutes then stops, if I am not mistaken.
philipwalker
Post by philipwalker » Fri May 11, 2007 8:42 am
As suggested above it is designed to dilute the exhaust emissions on cold start-up. It pumps fresh air into the exhaust. If there is a restriction or a sec air system pipe off it will throw up a code, as its emission relaited it will put the ecu light on as well.
New pumps are a bit pricy so look around for a s/hand one. Ask the servicing dealer to check that the pump unit faulty rather then a open circut.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
MEV
Re: RE: Secondary Air Pump ???
Post by MEV » Fri May 11, 2007 12:48 pm
philipwalker wrote:As suggested above it is designed to dilute the exhaust emissions on cold start-up. It pumps fresh air into the exhaust. If there is a restriction or a sec air system pipe off it will throw up a code, as its emission relaited it will put the ecu light on as well.
thanks guys I thought as much and makes sense Doug mentioned it was abit noisey on its last health check
Is it an esential part or can I take it out and do without??
dodgydave
RE: Re: RE: Secondary Air Pump ???
Post by dodgydave » Fri May 11, 2007 1:39 pm
The pump is no use to you. S4s don't have it. It's just to fool the o2 sensor to meet later emission standards on warm-up. You don't need it.
Never enough...
clived
Post by clived » Sat May 12, 2007 9:31 pm
So if you remove the pump, how do you stop the engine warning light coming on?
B7 S4 Cab
B5 RS4: MRC custom remap, Milltek 100cpi cats and rear system, RS6 8-pots, H&R PCS coilovers, H&R ARBs, AWE DTS, Tanoga Shortshift, Dynaudio / Focal / Genesis / iPod audio: SOLD, and still missed. One day....
rsw
Post by rsw » Sat May 12, 2007 10:35 pm
The secondary air system is used to warm the lambda probe and catalysts up as quickly as poss after a cold start.To do this it blows air into the exhaust system this does not dilute the exhaust gas but makes them hotter(a bit like turning on the oxygen supply of an acetaline torch makes the flame hotter)The car definately needs it to be working or it will keep throwing the eml on no way around it its part of the eu3 emission control of the ecu.Fault code is prob sec air low flow have fitted a few myself tend to go noisy then seize.
clived
Post by clived » Sun May 13, 2007 12:24 pm
I had what I assume was the original item fail after about 70k. The replacement (new, from main dealer) failed about 6 months later, replaced under warranty. This has now failed again (or at least, I have the fault code again, just yesterday - spooky!). Is there anything that could be causing the failure I need to investigate before having another pump fitted?
B7 S4 Cab
rsw
Post by rsw » Sun May 13, 2007 3:19 pm
Depending on what fault code you are getting check the fan function using final control on a vag com or similar,also check vac hose integrity to the secondary air valves on the back of the cylinder heads.tend to go brittle and split after time caused by the heat off the exhausts.
clived
Post by clived » Sun May 13, 2007 3:30 pm
Thanks RSW. I will check, but last time (on the new pump) failure was total - pump presented itself as a short circuit and of course therefore wouldn't spin ;-) I'm really after any thoughts on what might cause that - just bad luck, or something else in the system at fault?
B7 S4 Cab
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun May 13, 2007 3:49 pm
We remove th esecondary air injection from a lot of rs4s and 1.8ts and can disable the ecu checks for it.
http://www.MRCtuning.com
rsw
Post by rsw » Sun May 13, 2007 4:01 pm
why remove it?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun May 13, 2007 4:20 pm
why keep it? just another thing to go wrong and makes it easier working on the engines with it all removed.
cold start emmisions are not tested in this country.
clived
Post by clived » Sun May 13, 2007 6:08 pm
Doug, if you can disable the MIL, sounds great. To me it seems like a noisy item when it is working, and an annoying one when it isn't!
B7 S4 Cab
MEV
Re: RE: Re: RE: Secondary Air Pump ???
Post by MEV » Thu May 17, 2007 1:39 pm
Doug_S2 wrote:We remove th esecondary air injection from a lot of rs4s and 1.8ts and can disable the ecu checks for it.
Hi doug
do you remember her making the noise from the pump when she came up for brakes and a genric, service etc a few months back? Sounds as though its now failed according from the stealership. they want to charge some horrific price on a replacement and cant see the point if its not needed at all. Can it can be removed fairly easily? and if its not needed to be replaced for MOT etc. If so can you PM me and let me know if you'd do it for me, cost etc and perhaps lets slap on a milltek cat back at the same time !! Seems rude not while we're there Ill just tell her in doors the exaust as fallen off !
Cheers to all, quality info
