S4 B5 - speaker upgrade without too much faff?
Anyone running aftermarket front speakers want to chime in with models etc that will fit in the front doors without too much messing about.
Dont mind doing a little work (spacers or a bit of modding to brackets), just dont want to do anything not undoable.
Alternatively any ideas on the depth and size of the speaker mounting area so I can have a look around myself at all?
Just going to uprate the fronts to a decent set of components and amp them to get some better sound quality in there.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
RE: S4 B5 - speaker upgrade without too much faff?
I am running rainbow slx 235 deluxe speakers. They work very well, but you would ideally need an aftermarket amp to run them.
You need an adapter to allow you to fit the woofer to the standard mounting spot, the tweeter can be fitted to the standard tweeter spot no problem. It also comes with a large cross-over that needs to be mounted in the door, easily done though.
Problem with the B5 is the woofer "box" is not a box, the woofer just mounts to the plastic door card... if you put any power through it you will get distortion as the panel vibrates.
Yeah, amps a definite to get some quality sounds. Will be putting a 2 channel hidden out of the way somewhere.
I have done quite a few installs in the past which required all manner of door builds and jiggery pokery so not massively adverse to it, just want to avoid it if possible by buying speakers of the correct depth.
Can you get away with putting some brown bread/dynamat anywhere near the speaker hole to deaden that vibration at all?
Edit:
Also do you happen to know the sizes at all for the fronts? I had a look for the model you listed but can only find references to a 230 and 265, no 235
Edit:
Bobbler, give Audioscape a call they make bespoke door pods to a very high standard. At the very least you'd need to beef up the door trim with some extra fibreglass or MDF bracing.
I think you'd be safe with any 5.25" component set, the Rainbow's are quite expensive but sound very smooth, much better than Alpine, JBL etc.
If you need any sound deadening send me a PM, I have a full large sheet of the stuff.
Re: RE: S4 B5 - speaker upgrade without too much faff?
Thanks for that Peakz, but I think that Audioscape builds would push the price through the roof for the installation (which would take an extra £200 judging by their prices on the site). Fibreglass and MDF would also be into the realms of faffing about which I wanted to avoid if possible.Peakz wrote:Bobbler, give Audioscape a call they make bespoke door pods to a very high standard. At the very least you'd need to beef up the door trim with some extra fibreglass or MDF bracing.
Just wanted to bung some decentish speakers in the existing holes (with an adapter if required), run some cables to an amp and play.
RE: Re: RE: S4 B5 - speaker upgrade without too much faff?
I'm running Dynaudio in the front, but you absoutely need an amp....
Focal's in the back - not bad, but not a patch on the Dyn's
B7 S4 Cab
B5 RS4: MRC custom remap, Milltek 100cpi cats and rear system, RS6 8-pots, H&R PCS coilovers, H&R ARBs, AWE DTS, Tanoga Shortshift, Dynaudio / Focal / Genesis / iPod audio: SOLD, and still missed. One day....
Sounds like a nice bit of kit in your car, got any pix Clive?
I used to run a Genesis Four Channel with SEAS speakers.
I currently run a 200.4 phoenix gold amp... a little lacking in power to run my 2 x 10's in the back.
I really need some expert advice/help tweaking my install to be at its best. Anyone with suggestions please pm me.
As for the rainbows, sorry it was the 230's. I have adapters in the doors to fit the 5.25" cones. Most of the equipment came from caraudiodirect.com - they have all the adapters needed so you dont have to cut a thing in the standard loom, makes life much easier.
Re: RE: Re: RE: S4 B5 - speaker upgrade without too much faf
I haven't, but I guess I could take a couple at the weekend...Peakz wrote:Sounds like a nice bit of kit in your car, got any pix Clive?
B7 S4 Cab
Users browsing this forum: No registered users and 100 guests
