Guys I have seen some people say that the RS4 ECU upgrade does amongst other thing, align throttle bodies. I had a look yesterdy and can only find one throttle body.
Am I going mad or is there some mis-information around?
ECU upgrade and throttle bodies..
tartan_rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: ECU upgrade and throttle bodies..
I believe there are two but have to confess to not having looked but relying on info from techs at dealership. Will have to go have a look...........
Single Throttle Butterfly
From the US launch brochure:
A redesigned intake pipe system with a single throttle butterfly
and double-flow exhaust system with large diameter pipes
specific to this model further boosts the effective power output
Sorry, wrong. There is a throttle body (or throttle valve)
There has to be a throttle body (throttle valve, throttle butterfly), since homogeneous burn mode requires one. Audi mixes terminology. It is sometimes called a throttle body. It is other times called a throttle valve or throttle butterfly. But it does exist in the intake duct just before the intake manifold runner.
Otherwise it is called the Throttle Valve, and is part of the Throttle Valve Control Module, which is actuated by an electric motor controlled by the ECU.
In the manual there is even a part number for a throttle body gasket
079 133 073 C Throttle body gasket
Users browsing this forum: No registered users and 148 guests
