Along with other Audi projects I am blessed with a Ur Quattro which has among other mods a 6 speed 'box. I was using a RS2 clutch & pressure plate with a one off alloy flywheel.
The problem i have is that she is just tearing the friction material off the pressure plate. I have put this down to having no damping on either the plate or flywheel (and driving like a ****)
Have any of you guy's had similar problems with your RS2's fitted with alloy flywheels and how did you get around it. Thanks
Alloy Flywheel
- Corey
- 2nd Gear
RE: Alloy Flywheel
You need a sprung clutch, the RS2 item is unsprung due to the OE dual mass flywheel
Corey
Users browsing this forum: No registered users and 71 guests
