Remap issues + Removing the speed limiter
2.7 V6 30v biturbo - 380 bhp
Enne&Effe
Post by Enne&Effe » Sat Apr 21, 2007 2:22 pm
Hi all
I've just remapped my RS4 (made by a local engineer) and I have some troubles:
- at WOT everything is fine :D
- at 3/4 throttle, around 3500-4000 rpm the ECU goes in recovery, cutting the boost to 0,3 bar (normally is 1,3 bar). Releasing the throttle and pressing it again, the boost is full.
What is happening?
I've changed the N75, the lambda sonds, the boost pressure sensor, the MAF.....nothing changed..... :cry:
Any ideas?
Another thing: the engineer says that it is not possible to remove the speed limiter only remapping the ECU. The car needs an external device....is it correct?
Thanks in advance for your support
Enne & Effe from Italy :wink:
S2tuner
Trader (Expired)
RE: Remap issues + Removing the speed limiter
Post by S2tuner » Sat Apr 21, 2007 3:09 pm
I'd suggest you actually see a real tuner, not some "engineer" who doesn't know cr@p and talks rubbish.
The top speed limiter is INSIDE the ECU and your 3/4 throttle issue sounds about right for poor tuning IMHO.
HTH,
Mihnea
derdle
Post by derdle » Tue Apr 24, 2007 8:56 pm
Enne & Effe ... Plan yourselves a break and drive your car to "sunny" Oxfordshire! Enjoy a bit of a holiday and ahve your car sorted too!
ScottyBoy
Re: RE: Remap issues + Removing the speed limiter
Post by ScottyBoy » Tue Apr 24, 2007 10:03 pm
S2tuner wrote:I'd suggest you actually see a real tuner, not some "engineer" who doesn't know cr@p and talks rubbish.
HTH,
Mihnea
Maybe you know one in Italy Mihnea that you could recommend, now that would be helpful.
Black 51 RS4 **Sold**
MRC Stage 2+Custom Re-Map
Gutted Pre-cats + RS6 Clprs B7 Discs
Milltek exhaust Fats 3.3
Now its the Grim Reaper, if you feel a tap on your rear quarter its time..................to get out of the way.
S2tuner
Trader (Expired)
RE: Re: RE: Remap issues + Removing the speed limiter
Post by S2tuner » Thu Apr 26, 2007 12:33 am
No, honestly I don't know of a single decent tuner for an RS4 in italy, and I'm not trying to make myself look good. There are plenty of good Audi tuners, just unfortunately none that I've ever heard of in Italy so far....
Just my 0.02,
Mihnea
Enne&Effe
Post by Enne&Effe » Fri May 11, 2007 12:10 pm
Just talked with the mechanic: they put the original map but the problem remains exactly the same.
He is working on:
- air leaks
- ignition issues
Any other idea? Has someone experienced the same problem?
Thanks a lot for your help
Contigo
Post by Contigo » Mon May 21, 2007 4:19 pm
Had similar thing to you (see the hesitation at around 3k-4k rpm thread)
Get the car pressure tested and check for any possible boost leaks.
It could be the diverter dump valves that have gone as I had mine replaced.
What fault codes does VAG COM software give?
Mine went into limp mode (flashing engine management light for 10 seconds) and then all came good again and would perform fine for a certain period.
Nige_RS4
Post by Nige_RS4 » Mon May 21, 2007 4:45 pm
Have you checked your plugs & verified your EGT sensors are OK?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Enne&Effe
Post by Enne&Effe » Tue May 22, 2007 3:37 pm
Just talked with my mechanic and every problem seems to be solved. The issues were:
- small air leak in a dump valve hose
- wrong N75 valve (!!!): it has recently been replaced but with a wrong one (suppplied by local Audi dealer basing on chassis number)....no words....
- too warm spark plugs (they were original ones) -> sometimes the car knocked
Now it seems fine: on Saturday I will go there to finally test it!!!
Users browsing this forum: No registered users and 71 guests
