RS4 Alignment numbers/spec
2.7 V6 30v biturbo - 380 bhp
Alexb76
Post by Alexb76 » Sat Apr 14, 2007 5:33 pm
I am getting an RS4 suspension installed on my S4 and I wanna do a 4-wheel alignment, but they don't have the right alignment numbers for RS4 to do it properly, all they have is the S4 numbers.
Anyone's got those numbers to share please?
Thanks!
Alexb76
Post by Alexb76 » Thu Apr 26, 2007 7:22 pm
anyone with access to dealer DB or maintenance manual for RS4 would know this... I am in Canada so we don't have RS4 and therefore no access to that info.
p.binks
Post by p.binks » Thu Apr 26, 2007 10:29 pm
Hi there just had my RS4 alligned and these are the spec's.also try (B6/B7) avant sport suspension A4/S4/RS4 quattro:2001-
Front
left specified range right specified range
Camber -1deg35' -0deg22' -1deg35' -0deg22'
toe 0deg05' 0deg15' 0deg05' 0deg15'
turning angle diff -1deg36' -0deg36' -1deg36' -0deg36'
toe raised 0deg07' 0deg21' 0deg07' 0deg21'
cross camber -0deg30' 0deg30'
total toe 0deg10' 0deg30'
cross toe raised -0deg10' 0deg10'
Rear left spec range right spec range
camber -1deg50' -0deg50' -1deg50' -0deg50'
toe 0deg08' 0deg15' 0deg08' 0deg15'
total toe 0deg15' 0deg30'
thrust angle -0deg10' 0deg10'
hope this helps, deg= degree's '=minutes
:nogarors4: :beerchug:
2002 Noggy RS4,AP 6 pots,Revo,H&R big arb's,milltek.
Alexb76
Post by Alexb76 » Fri Apr 27, 2007 5:00 am
THANKS A LOT MATE!!!
That's exactly what I was looking for... cheers!
p.binks
Post by p.binks » Fri Apr 27, 2007 10:50 am
No problem happy to help.
:nogarors4: :FIREdevil: :FIREdevil: :biggrin3:
Alexb76
Post by Alexb76 » Wed Jul 11, 2007 9:21 pm
p.binks wrote:Hi there just had my RS4 alligned and these are the spec's.also try (B6/B7) avant sport suspension A4/S4/RS4 quattro:2001-
Front
Are you sure these numbers are correct? If so, the car has to be setup with positive Toe (toe out)...
I aligned my S4 with RS4 suspension and they set the toes at 0.0 and it doesn't handle well... but still not sure if it makes sense to toe out the car....
Anyone has any ideas regarding this?
Thnx
Alexb76
Post by Alexb76 » Thu Jul 19, 2007 5:17 am
Any help out there?
simon_golf_tt
Post by simon_golf_tt » Thu Jul 19, 2007 8:07 am
When you say fitted RS4 suspension - do you mean just the dampers and springs? If so, surely the S4 geometry settings are still what you need?
2006 Sprint Blue RS4 Avant (for sale)
2007 A6 3.0TDI LeMans saloon
2001 Misano RS4 (gone)
2001 Noggy RS4 (gone)
flashyg
Post by flashyg » Thu Jul 26, 2007 12:01 am
The toe is definitely negative.
Never positive.
G
