Help with VAG-COM Scan results.
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
stimp
Post by stimp » Wed Mar 28, 2007 7:57 pm
Hi Chaps,
JUust scanned my car and have the following faults. Anyone shed any light on causes and solution would be great. I only have a shareware version so can't read a couple.
16502 Engine coolant temp sensor(G62)Signal too high.
P0118-35-10...intermit
18010-?
P1602-35-10...Intermit
18047-?
P1639-35-10...Intermit
17963-Charge Pressure.Max Exceeded
P155-35-10 Intermit.
I geuss the top one is a temp sender, possibly related to the issue I have with the temp gauge sometime fluctuating. No idea on the second two. Number 4 prob due to remap.
All thoughts and any decoding of the middle too appreciated. :D
stimp
RE: Help with VAG-COM Scan results.
Post by stimp » Wed Mar 28, 2007 8:11 pm
Found some:-http://wiki.ross-tech.com/index.php?tit ... 18%2FP0734
Just missing the third one. 18047 ?
Bingo...
2000 Audi S4 with the following message via VagCom/HexCom 504.1-D
VAG-COM Version: Release 504.1-D
Control Module Part Number: 8D0 907 551 A
Component and/or Version: 2.7l V6/5VT G 0003
Software Coding: 06611
Work Shop Code: WSC 30011
1 Fault Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-00
ChipHazzard
Post by ChipHazzard » Wed Mar 28, 2007 8:24 pm
I would think you have a boost leak, check you tbb & f-hose as these are the usual culprits then either get a pressure test done or get it up to MRC for a full health check
HTH
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
nickb834
Post by nickb834 » Thu Mar 29, 2007 1:30 pm
regarding the accel position sensor, I'd check the resistance across the first potentiometer.
Dunno if you know but the throttle is purely electronic on these cars, the position of the throttle is determined by the resistance measured accross two sets of potentiometers.
Potentially you have a failure of the first one, the car is still obviously driveable like this but you now have no reduundancy. A potentiometer is basically a strip of a carbon / graphite material with an arm that moves across it, as the arm moves the resistance varies. Over time the arm "scrapes" some of the carbon / graphite material away which creates a dust. As the arm moves and comes into contact with the dust you can have sudden increases / decreases in resistance instead of a nice gradual increase / decrease.
This is probably whats going on here. Upto you whether you do anything about it. Personally, I'd say no rush - keep your eye out on eBay for a throttle position sender for an A4 and snap it up - fit it when the whether turns nice again!
Nick
Wanted: C5 RS6 Avant
Audis are cheaper than women, and when they finally leave they don't take your kids and half your stuff....
although smack either one about and the police turn up ;-)
derdle
Post by derdle » Thu Mar 29, 2007 4:30 pm
Note: Fault 4 normally causes the car to go into limp home mode to save the turbos.
Paul
Users browsing this forum: No registered users and 74 guests
