Rear caliper rubber boots
Does anyone know whether it is possible to range the rubber boots around the rear caliper piston and if so how difficult it is. My dealer says I have to buy new calipers !!
RE: Rear caliper rubber boots
I'm sure you will be able to strip the caliper down to change them - If you can get them. Talk to the parts guys to see if the boots are called off or alternatively check the ETKA parts listing yourself.
http://www.vagcat.com/
You'll have to register - its free.
Failing that I'm sure the standard front Calipers are made by Girling check the caliper for the manufacturers name then try a motor factor.
If you can get the service kit which will come come with new seals and pistons etc. These are typically less than a £10.
