Help Bleeding Clutch
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
dub2dub
Post by dub2dub » Mon Mar 19, 2007 10:08 am
Having a few problems bleeding my clutch after replacing the slave cylinder. Im using an eazi bleed which I have attatched to the reservoir, made sure the clutch pedal is pulled right back and plonked it in 3rd gear as per workshop manual, but when I open the bleed nipple nothing comes out, its as if something is blocking it.
Am I doing something wrong or could it be a faulty clutch master cylinder?
thanks in advance
dub2dub
RE: Help Bleeding Clutch
Post by dub2dub » Fri Mar 23, 2007 9:38 am
Anyone?
dub2dub
Post by dub2dub » Mon Mar 26, 2007 4:17 pm
Ok, finally got the stupid thing to bleed but to no avail, have a sort of pedal but absolutely no clutch.
Having now replaced the friction plate, pressure plate, release bearing and slave cylinder, the only thing I have not replaced now is the clutch master cylinder so just ordered one up.
Just wondered if anyone has any tips on fitting it (looks pretty straight forward but then most things do until you start it :roll:)
MarkB
Post by MarkB » Mon Mar 26, 2007 4:29 pm
:shock: I had a mini years ago that the clutch didn't work on. After changing most parts found it was the arm that operates it. The ball on the in had broken so wasn't lifting the bearing.
Mark
eddiecrawford
Post by eddiecrawford » Wed Apr 11, 2007 10:33 pm
how did you get on? did you fix it?
i am having trouble getting a spanner to move the bleed nipple, there is too much stuff around it. i can get a socket on no problem, but then oil will go everywhere. (9mm)
am i missing something?
thanks
eddie
eddiecrawford
Post by eddiecrawford » Thu Apr 12, 2007 11:25 pm
easy.....
the bleed nipple was only on finger tight!!!!!!! after 129k. hope i didn't overtighten it...
Users browsing this forum: Google [Bot] and 76 guests
