Beeping (not 4 beeps) as I drive
Every now and then the car starts beeping at me, 1 beep every 10 seconds or so. No warning lights come on, and I get an OK when I start up. It eventually goes away, although last week it went on for around 5 minutes. Anyone any ideas ?
Have you had a good look in the manual, there are lots of little settings that you can do with the car that sometimes you dont even know youve done eg. yesterday i set some speed thingy it came up as a circle with the number 1 and mph in it and that kept beeping.
Black 51 RS4 **Sold**
MRC Stage 2+Custom Re-Map
Gutted Pre-cats + RS6 Clprs B7 Discs
Milltek exhaust Fats 3.3
Now its the Grim Reaper, if you feel a tap on your rear quarter its time..................to get out of the way.
It's not to do with the radio (I turned that off) and it's not to do with speed limits (that shows up on the DIS). It might be to do with oil pressure as I've noticed it takes a while to lift off 60, longer than it used to. But if it was low oil I would have thought the DIS would have said something.
Any more ideas ? Thanks in advance.
Re: Beeping (not 4 beeps) as I drive
Oil Pressure????? That's your Oil Temperature Gauge surely!!!!ptkend wrote:It's not to do with the radio (I turned that off) and it's not to do with speed limits (that shows up on the DIS). It might be to do with oil pressure as I've noticed it takes a while to lift off 60, longer than it used to. But if it was low oil I would have thought the DIS would have said something.
RE: Re: Beeping (not 4 beeps) as I drive
You could always check your oil level using the old fashioned dip stick approach
APR 270bhp S3, Mixer K6 750
Pressure, temperature, whatever. I know my Boyle's law
. The fact is, I know it's not to do with the oil (I have now checked).
So no-one knows what this could be ?
RE: Beeping (not 4 beeps) as I drive
Have you tried the TP button on the radio? Mine was also turned off but I had to clear the memory......I think!!
Yes,
Its been said already, if it was on a long run its the warning telling you to take a break, it should say 2H in the dash to say you have been driving 2 hours.
If you dont stop or leave the ignition running on short journeys it still counts up.
_______________________________________
2001 Misano RS4
2001 Misano RS4
Users browsing this forum: No registered users and 105 guests
