Vibration through the Steering
nigel@flawith.com
Car is a is 1995 RS2 with 115K miles.
I can feel a vibration through the steering at speeds > 70mph. Initially it feels like a wobble and then the frequency goes up with speed and it feels like vibration.
Having had the wheel balance checked, I think the problem could be a wheel bearing?
Before heading off to my local dealer I'd like to hear from any one who has experienced the same or similar problem and what was the cause.
I too have a vibration of the steering wheel. It's not heavy. For me, this is apparent only at speeds 50-60 mph. Especially around 55/57mph. The vibration is noticable on accelaration or decceleration as well as cruise or throttle lift.
I've has wheels balanced/swapped, new brakes fitted, discs checked for run-out, new wishbone bushes. 4 wheel alignment. The vibe is less than it was but is still there.... I suppose many people wouldn't notice it on driving the car but I would still like to solve this minor problem.
Any ideas?
Any ideas?
Lloyd
RS2+
RS2+
I've got fancy mance mount savers for the top mounts from Corey, new from just 5 months ago. Don't think the prob is there on my car..... Mebbe it's the hubs? or wheel bearings?alastairg wrote:Topmounts. Just replaced my 2 year old ones at MRC. One was knackered. If not get a proper 4 Wheel alignement done (?all four tyres wearing evenly ?)
Lloyd
RS2+
RS2+
I've had a bit of steering wheel vibration from A) wheels out of balance - had to balance them twice to get rid of the vibration. B) very slight vibration plus droning from shot wheel bearings and the after replacing bearings continued slight vibration & droning from wheel bearing centre bolt not be done up to correct torque.
RS2 +
nigel@flawith.com
Thanks for all the ideas. I tried everything suggested above but didn't find the solution until I got a puncture. The cause of the puncture and vibration was a faulty tyre. Now with a new tyre fitted the vibration is gone.
The reason why the vibration didn't show up when I took the wheels to be balanced is the there needed to be a certain amount of heat in the tyre.
Interesting as I have a similar problem with vibration after replacing the usual suspects. Then on getting a wheel balance done by a trusted 'one man alignment specialist' he noted a high spot on the tyre (P zero). I have switched backs with fronts with some improvement (we did not check the rears).
In addition the tyre is likely as pressures & ambient temperature seem to affect the vibration.
