Thermo Tec
Thermo Tec
I'm not convinced by ceramic coating of turbo's and manifolds but do like the look of these
What do others think?
Mark
- SimonS4MTM
- Top Gear
RE: Thermo Tec
I have some gold F1 style tape here. I am not sure what the maximum operating temperature of it is though, probably not high enough for turbo's.
When I get around to it, I will use it for shield the airbox.
RE: Thermo Tec
i sheilded my air-box and air intake ducting with sticky silver tape..it worked very well..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
RE: Thermo Tec
I have also now done this woody. I got a job lot of the stuff a while back
Wide Body S4
RE: Thermo Tec
well ceramic is also used for speeding up exhaust gas exit on the surface, reflecting more energy back on to the turbine wheel and increasing the life of those parts, i don't think it is primarily for insulating against heat to stop it spreading around your engine bay and intake, for which your solution here is more to that point.
philipwalker
- 5th Gear
RE: Thermo Tec
A few years back wrapped a fancy manifold with similar stuff, yep the underbonnet temps went down but the heat ended up elsewhere on the exhaust system.
Ended up melting the exhaust rubbers!
Re: RE: Thermo Tec
I thought the ceramic coating was on the outside, not the inside?dummi wrote:well ceramic is also used for speeding up exhaust gas exit on the surface, reflecting more energy back on to the turbine wheel and increasing the life of those parts, i don't think it is primarily for insulating against heat to stop it spreading around your engine bay and intake, for which your solution here is more to that point.
Mark
Re: RE: Thermo Tec
I can beleave that! but the exhaust has the advantage of being in the free air under the car.philipwalker wrote:A few years back wrapped a fancy manifold with similar stuff, yep the underbonnet temps went down but the heat ended up elsewhere on the exhaust system.
When the time comes I'm tempted to do the manifold, turbo exhuast housing and upper downpipe.
Possibly also reflective covering over the inlet pipework
Mark
RE: Re: RE: Thermo Tec
errr depends what your doing!
RE: Re: RE: Re: RE: Thermo Tec
shoot Jacob Buehn an email he offer ceramic coating on his hybrids
