Hi all
Anyone managed to get these off without damage?
Any useful tips?
Wheel speed sensors
- SimonS4MTM
- Top Gear
Wheel speed sensors
RE: Wheel speed sensors
Be warned they can be a right B****r so don't expect to do this quickly as patience will very possibly be required. I used a combination of rotating the sensor while prising gently out of the upright and they took me rather a long time.
Some come out easy and some are a – well you can guess.
Definitely an evening with a beer and good music job.
Good luck!
Good luck!
S4B5 Avant
- SimonS4MTM
- Top Gear
That's what I thought. I had a go the other weekend and they would not even rotate.
I think a few applications of WD40 will be required.
philipwalker
- 5th Gear
Re: Wheel speed sensors
No, they generally break when you attempt to twist or pull them out.SimonS4MTM wrote:Hi all
Any useful tips?
You may be lucky !
RE: Re: Wheel speed sensors
I guess I must of been lucky then as managed to get both rears out of my MY2000, soaked them overnight with 'Break Free' then with wrapped a strip of gaffer tape around the barrel(?) and locked on a small pair of mole grips. gentle twisting / prising eventually had them out - bugger of a job. Before putting them back cleaned up the hole with emery and gave them a good lube with silicone grease.
S4B5 Avant
