Is the reservoir the one on the left at you look at the car from the front with the green cap?
What fluid goes in there? Mine is below the dipstick. Can you buy fluid at a petrol station?
Power Steering
- shineydave
RE: Power Steering
that's the one, in front of the washer bottle. needs to be the correct grade which unfortunately most garages and car accessory retailers don't stock. i've got it from parts factors like Andrew Page in the past
RE: Power Steering
how do you find out what grade?
- boxerdogted
RE: Power Steering
It is in the handbook and is mineral oil so dont put std ATF oil in there as they do not mix and you will end up with expensive leaks from the steering rack and pump.
Available from any Audi/ VW/ Skoda dealer, Part number G 004 000 M2.
Hope that helps you.
2001 RS4 Misano Red
