how the hell do you.... airbox clip!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
fil
Post by fil » Sun Feb 25, 2007 3:05 pm
just changed the plugs well 3 airbox side, the rain stopped play, but how do you get to the back airbox clip, my arms aint that fat!
what a pain, have left it uncliped at the mo, i just cant get it back on, tried levering it on with a screewdriver, but there just aint any room to do it.
still at lease the otherside with washer bottle looks less of a pain!
still smiling tho :)
99 S4 minging blue avant
nickb834
Post by nickb834 » Sun Feb 25, 2007 4:12 pm
It's a right pain that clip!
I found that doing that one first with a screwdriver, and then the others was the best technique.
Still a sod though ;-)
Wanted: C5 RS6 Avant
Audis are cheaper than women, and when they finally leave they don't take your kids and half your stuff....
although smack either one about and the police turn up ;-)
fil
Post by fil » Sun Feb 25, 2007 4:36 pm
cheers , will give it ago, got the other 3 plugs done, raining again now :(
shineydave
Post by shineydave » Sun Feb 25, 2007 6:07 pm
yup, i had trouble with that little number too, i also attached it first, helps if you push down on the airbox lid and fortunately i have dainty little gurly hands so i managed to get a finger on it, just.
Philws4
Post by Philws4 » Sun Feb 25, 2007 6:54 pm
Out of interest Fil what make plugs did you fit?
B5 S4
fil
Post by fil » Sun Feb 25, 2007 7:05 pm
NGK laser platinum PFR6Q
jimbogrey
Post by jimbogrey » Sun Feb 25, 2007 9:07 pm
Trying to separate the two halves of the airbox in situ is way too fiddly so I find it is better to remove the box complete and open it up outside the car.
Jimbo
tartan_rob
Post by tartan_rob » Mon Feb 26, 2007 10:10 am
I used to do the awkward clips first but totally removing makes more sense.
R
2017 Kawasaki Z1000
2014 RS6
2014 S1
ronaldmacdonald
Post by ronaldmacdonald » Mon Feb 26, 2007 8:04 pm
lol, i remember that beeeeaaaatch of a clip, it was such a knuckle grazing knightmare in fact that I just left it unhinged - to no ill effect :shock:
i think the way to do it is do that clip first as has been said - i tried that way as well and failed...
UKS4APR1
Post by UKS4APR1 » Fri Mar 02, 2007 12:50 am
Use a bit of sturdy wire or coat hanger....
yank it up into place
fil
Post by fil » Fri Mar 02, 2007 2:04 pm
time too make a new tool for the tool box :D
jimbogrey
Post by jimbogrey » Fri Mar 02, 2007 11:00 pm
I am still confused as to why you would need to undo the air box clips in situ. I presume that you have already undone the MAF and unclipped the various sensors and pipes befor you undo the clips If so then it is simply a matter of undoing one nut and the entire airbox just lifts out. give it a go you wont believe how easy it is.............or am I missing the point?
Jimbo
PS Whilst its out you can drill lots of holes in it!!
fil
Post by fil » Sat Mar 03, 2007 5:46 am
I left the maf and everything attached, just needed to move it out the way for spark plug access
