RS4 Flywheel and Clucth info required
jc..
Post by jc.. » Wed Feb 14, 2007 2:07 pm
Could someone help me with some technical q's on the B5 RS4 clutch and flywheel.
Is the Flywheel dual mass?
What is the bolt pattern to the crank
What is the clutch rated to? (over 450 lb/ft?)
Has anyone had any trouble with the OEM clutch and flywheel on boosted application (overheating, slipping, disintergration etc)?
Anyone have an aftermarket light flywheel?
If anyone has a pic of the OEM clutch or flywheel I would be very grateful
sorry for the 20 questions, but I am getting lots of misinformation from tuning companies trying to pedal aftermarket lightweight flywheels.
Doug_S2
Trader (Expired)
RE: RS4 Flywheel and Clucth info required
Post by Doug_S2 » Wed Feb 14, 2007 10:21 pm
ali flywheels are good unless you slip the clutch to launch - then they get too much abuse and heat so the ali tends to warp.
stock rs4 clutches should be ok for a normal road driving upto 480ft-lb ish. If you launch or track it won't last long though.
stock FW is dual mass and very heavy.
I have seen a stage 1 car with 2 clutches that have disintergrated.
http://www.MRCtuning.com
jc..
Post by jc.. » Thu Feb 15, 2007 6:34 pm
what kind of clutch fell apart? OEM? Do you know what the size/weight of standard RS4 flywheel is? or the bolt pattern..
cheers
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Feb 15, 2007 6:48 pm
stock rs4 fell apart -not common though. got flywheels here but need to weigh them. bolt pattern - i don't know what you mean - they are audi fitment.
quattrosteph
Re: RE: RS4 Flywheel and Clucth info required
Post by quattrosteph » Thu Feb 15, 2007 11:55 pm
Doug_S2 wrote:ali flywheels are good unless you slip the clutch to launch - then they get too much abuse and heat so the ali tends to warp.
Damn.... mine is 520 fT-lb , better to take it easy at Donington Park. :?
Porsche 996 Turbo S Atlas Grey.
RS4 B7 Avant Sprint Blue. Sold.
RS4 B5 Avus Silver with MRC magic . Sold (Best car ever )
S4 B6 Avant Nogaro blue. Sold
A6 Avant Silver . 2.5 TDI .Sold
jc..
Re: RE: RS4 Flywheel and Clutch info required
Post by jc.. » Fri Feb 16, 2007 12:27 pm
Doug_S2 wrote:stock rs4 fell apart -not common though. got flywheels here but need to weigh them. bolt pattern - i don't know what you mean - they are audi fitment.
Thats great.
Are the flywheels on A4 S4 and RS4 different sizes?
By bolt pattern I mean the flywheel end of the crank.
will an S4/RS4 flywheel fit an non V6 crank to enable me to fit a higher rated OEM clutch to a big turbo 4 cylinder bottom end.
Is it possible to lighten a dual mass OEM flywheel at all?
thanks for you help
Users browsing this forum: No registered users and 31 guests
