Quattro vibration
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
QuantumJohn
Quattro vibration
Post by QuantumJohn » Wed Feb 14, 2007 1:54 pm
Searching through some previous posts I found some people mentioning a vibration coming through the transmission when turning a corner. It feels similar to the tyres scrabbling for grip with a light understeer.
The general consensous was that this was normal and that a 4 wheel alignment would sort it.
I have this and having been in another b5 S4 that didn't have it know it is cureable. I can't find any posts that mention whether the 4 wheel alignment cured the problem.
Anyone?
Thanks,
John
MarkB
RE: Quattro vibration
Post by MarkB » Wed Feb 14, 2007 2:11 pm
Mine give that sort of feeling when turning on tight lock. I put it down to quattro and the fact I have 33mm offset wheels whcih push the wheels out of the arches further than standard. Seems fine at speed
Mark
gavsteryoung
Post by gavsteryoung » Wed Feb 14, 2007 2:34 pm
I've heard this is normal!
Mine does it, but only when the cars hot. Like a dog dragging its back legs! ;-)
Wonder if its related to the diff oil.... maybe an oil change is in order!
09 Audi S3 - Sprint Blue
99 Audi S4 - Ming Blue - (Gone but not forgotten)
04 Vauxhall Tigra 1.8 Sport - Antiga Blue (The Mrs Car)
SimonS4MTM
Post by SimonS4MTM » Wed Feb 14, 2007 4:34 pm
There are two different effects.
Front tires slipping, on full lock at low speed, especially on a wet road is alignment.
Grinding/growling/groaning from the rear when pulling out of a junction with a bit of welly, is normal torson feature.
joss1
Post by joss1 » Thu Mar 29, 2007 4:18 pm
How about a rumble, coming it seem from the front, on quick bends, equal both left and right sides, like going over painted strips on the road, any suggestions?
rikrose
Post by rikrose » Thu Mar 29, 2007 4:30 pm
A series of hedgehogs. Check your tyres.
Goodwood green RS4, previously owned by jeffw
joss1
Post by joss1 » Thu Mar 29, 2007 5:21 pm
Much appreciated, must do !)
Tyres checked, changed, rechecked, no improvement.
alignment checked & rechecked, fine.
Balance also repeatedly checked, in different garages.
How does Driveshaft imbalance or diff damage present?
Johh
h8cak
Post by h8cak » Fri Mar 30, 2007 1:28 pm
I think all quatros do it. Mine was made worse by having a set of locking wheel bolts which were too long and rubbing one of the main arms when on full lock. All sorted now tho but still get the very mild vibration.
Wide Body S4
Dippy
Post by Dippy » Fri Mar 30, 2007 1:48 pm
Come to think of it, mine doesn't do it anymore (as far as I have noticed).
4-wheel alignment did not cure it, so in my case it must have been one or all of:
Tyres (running PS2s now)
Wheels (18" RS reps)
Suspension (H&R coilovers)
2001 Silver S4 Avant
ZeroK66
Post by ZeroK66 » Fri Mar 30, 2007 5:15 pm
Mine hardly does it anymore to be honest... it used to quite a bit. Guess wheel, suspension and tyre setup can reduce it - I am talking about the rear grumbling noise at slow speed.
Your problem seems to be something else that sounds a little more serious... really should get it checked over by someone else, or go for a drive with someone here that has an S4 to compare.
