I have run a fault code scan on the S4 B5 and got some stuff back that doesnt realy mean a lot to me, does anyone have a list of the codes, and what they actually mean in plain english?
for example what does key 1 adaption limit surpassed mean? or alarm triggered by terminal 15? what is terminal 15?!
im sure there is something on this site somewhere, but I can never find anything using the search!
thanks in advance
does anyone have a list of what the DTCs ACTUALLY mean?!
- shineydave
RE: does anyone have a list of what the DTCs ACTUALLY mean?!
don't know whether this is what you're looking for
http://www.bentleypublishers.com/tech/a ... .table.htm
failing that try searching the ross-tech website
- 1st Gear
It means your central locking system hasn't seen this key in a while and it *may* be necessary to re-synch it.what does key 1 adaption limit surpassed mean
It means the terminal 15 turned on without the alarm having been properly disarmed first.alarm triggered by terminal 15?
Terminal 15 is switched power (this is a DIN or ISO standard).what is terminal 15?!
Bosch has a lot of good literature that explains how stuff works:
http://www.bentleypublishers.com/bosch/index.htm
High on the list:
http://www.bentleypublishers.com/product.htm?code=h009
-Uwe-
