Driving Lights
Driving Lights
I have noticed that the driving lights are only activated on the front of the car, I was sure I hand read on here that there was a way of re-programming such that the tail lights would also activate. Has anyone else done this that can advise how to go about it?
- PetrolDave
RE: Driving Lights
By Driving lights I presume you mean the DRL (Daytime Running Lights)?
The standard UK coding enables only the front lights, but a simple coding changes enables the rear lights as well. I did this to my RS4 a couple of months ago - you need to change the coding of the Central Electronics Module (address 09) from xxx2x to xxx4x.
- PetrolDave
- PetrolDave
On a B7 RS4 you need either a HEX-COM+CAN (if your laptop has a serial port) or a HEX-USB+CAN (if your laptop only has USB ports).
The cheaper micro-CAN will only work on Golf V platform cars (like the 8P A3), and older ones like the HEX-COM or KEY-COM won't be able to talk to all the control modules on a B7 so IMHO they're a false economy.
Most, probably all, the leads on eBay won't work with recent versions of VAG-COM so there will be some settings you can't read or change.
Many people with these third party leads have problems accessing control modules that just go away when they use a genuine lead.
The choice is yours - save a bit of money and maybe have problems that are only solved by spending on the proper thing, or ...
- PetrolDave
All B7 RS4 have bi-xenon lights which means both dipped and main beam use the same (centre) lens in the headlamp.Riz_RS4 wrote:It might be a dumb question but what daytime running lights exactly?
I assumed it was just a fancy name for switch on your side lights.....
The outer lens is obviously the indicators (even more obviously for those unlucky enough to have the nasty piece of orange plastic!).
Which leaves the inner lens - which has two bulbs, one 5W one for sidelights and one 21W one for Daytime Running Lights.
Press and turn on the tiny switch marked DRL just beside your light switch - with the engine running you'll see the brighter bulb in the middle of the lens lit (the sidelight bulb is offset).
Users browsing this forum: Zyox and 47 guests
