weird problem....
2.7 V6 30v biturbo - 380 bhp
hayden
weird problem....
Post by hayden » Thu Jan 25, 2007 5:32 pm
for some strange reason, as of last night, on remote unlock / door opening, the interior lights dont turn on, and dash does not show door open/mileage (cant remember if it did before or not).
interior lights can be switched on manually at switches and all work fine...
Also if locking with key, it locks (centrally) fine and arms, but on unlocking with key, it doesnt unlock all doors only drivers and also doesnt un-arm...
Anyone got any ideas??
Ta
hayden
shineydave
RE: weird problem....
Post by shineydave » Thu Jan 25, 2007 5:51 pm
think it sounds like a problem i had, check (i think) fuse 30, in any case it's marked up as interior light on the lid of the fuse box. have the indicators stopped flashing on arm/disarm as well?
Golich
Post by Golich » Sun Jan 28, 2007 10:37 am
Do you have VAGCOM? Check for DTC (error codes)
Is your passenger footwell carpet damp?
The ECU for controling all of this is under the carpet and can get wet from a leaking Pollen filter housing to car body seal. I noticed my seal has perished and allowed some water in after a serious down pour we had in the summer. Nothing happened to the car and it all dried out fine with no drama. But by chance I read a technical article in Audi driver which explained this apparently common fault on both the A6 and A4s.
Of course it maybe nothing to do with this but as a matter of routine you should have a look around the pollen filter housing for the build up of excessive dirt and leaves which then allows water to get over the lip in the body and allows water down in through the heater blower.
shineydave
Post by shineydave » Sun Jan 28, 2007 10:56 am
Tied in with Golichs post, it might be worth checking in the right hand side of the boot where the alarm siren/central locking controller is housed. i've read previous posts about the well where it's located filling with water and drowning the unit.
Nige_RS4
Post by Nige_RS4 » Sun Jan 28, 2007 12:51 pm
Patrick, did you see my post about removing the bulkhead drain plug(s), as these are known to become blocked over the years?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Golich
Re: RE: weird problem....
Post by Golich » Mon Jan 29, 2007 9:42 pm
Yes Nige 10mins after I wrote the above - top tip! 8) I'll be looking at mine very soon.
Cheers :)
Users browsing this forum: Majestic-12 [Bot] and 156 guests
