Login ID for B6 S4
tartan_rob
Login ID for B6 S4
Post by tartan_rob » Wed Jan 17, 2007 4:49 pm
I need a B6 S4 login ID for the Central Conv controller. Anyone got one?
2017 Kawasaki Z1000
2014 RS6
2014 S1
PetrolDave
RE: Login ID for B6 S4
Post by PetrolDave » Wed Jan 17, 2007 8:26 pm
Not sure why you need a login ID - I've never been asked for it when changing the settings on the central convenience controller.
What are you trying to change?
tartan_rob
Post by tartan_rob » Thu Jan 18, 2007 10:01 am
I am trying to re-code it and the code is not accepted. When I say that, it appears as if it is, but when I go back into the module, the code has not changed. Adaptation works fine however.
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Thu Jan 18, 2007 4:31 pm
I all likelihood, you are trying to enter a coding value which is not acceptable the module.
We can probably help you if you post details of your module, the original coding, and explain what you want to change.
-Uwe-
tartan_rob
Post by tartan_rob » Fri Jan 19, 2007 2:22 pm
Uwe - the new cable arrived yesterday from you. That seems to have done the trick. Thanks.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 65 guests
