Hi
Does anyone know where it is? Easy to change?
Pollen filter location on S3
APR 270bhp S3, Mixer K6 750
philipwalker
- 5th Gear
RE: Pollen filter location on S3
It is located on at the bottom of the windscreen on the near side, under a black plastic cover. Remove the cover screws and unclip the filter, make sure you dont drop all the crud on top of the filter into the heater air box. Remove the filter from the black plastic frame replace with the new one and refit the correct way round.
The part number for the filter is 1J0819644A it will cost you £15 from your dealer
I'm not sure if this has been replaced before, so could be 64k miles/6 years old....
