GEARBOX on RS6
GEARBOX on RS6
My RS6 seems like a slipping on the auto box. On the odd occasion when I put my foot down to about 3/4 pedal from approx 1/4 pedal, the revs rise as they should. Then as I get to about 4800rpm I get a sudden bang from under the car. Then it carries on as it should. If it was a manual car, its as if the clutch was slipping then it suddenly engages. Is this a common problem.Any ideas?
RE: GEARBOX on RS6
My idea would be to stop driving it before you seriously bugger something up and call your dealer to have the car recovered and claim on the warrantee.
RE: GEARBOX on RS6
Thanks. It has happened maybe 4 or 5 times in the last 3 months. It was suggested it might be the torque converter?
RE: GEARBOX on RS6
It may be less likely to happen in a different gearbox mode like M or Sport, as they both lock-up the clutch sooner (and at lower revs) than D.
RE: GEARBOX on RS6
Take it to a dealer mate, they might change the oil for you esp if it was low already as a first measure and if it doesnt get any better, then they'll end up changing the whole gearbox. Hopefully you'll have extended warranty
I think the torque converter can be changed seperatley but more often than not, they change the whole box. The box is not servicable.
RE: GEARBOX on RS6
Interesting - if I floor it in my car, full throttle travel - I will sometimes get a similar thing. Always put this down to the sheer forces involved as it lurches forward - torque converter or drive shaft...
Read a similar thread a while back.
Ed at APS for one I'm sure will gladly give you a view on it. Keep us posted!
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
RE: GEARBOX on RS6
Sudden bangs at 4800rpm cant be good for all things mechanical. Problem will be in demonstrating the fault if its that infrequent. Good luck, and let us know how you get on.
Present:...
Past:
Past:
RE: GEARBOX on RS6
Gearchange should ALWAYS be smooth. And there should certainly be no slipping of the clutch.
Try it from the lights in tiptronic when warm. Take it up to the red line in 1st, hold it there, then change to 2nd. It should change instantly, no noises. If not, then you definately need a new box.
Also after a long hard run, put your window down and drive the car slowly, ensure there is no transmission whine, another symptom of box failure.
RE: GEARBOX on RS6
This is 100% the gearbox, have replaced 3 now with exactly the same symptoms. The gearbox oil will be black where the clutches have been slipping in the torque converter. If your dealer is stingy they'll just replace the converter but hopefully you'll get a shiny new gearbox.
If it aint broke then dont try to fix it!
B5 RS4
MRC 420+Expired Precats
PCCB Calipers x4-B7 Discs x4
R8 Handbrake Calipers
Milltek
710N's
B5 RS4
Milltek
710N's
RE: GEARBOX on RS6
The exact same things happened to my RS6 leading up to total Tiptronic failure.
Clutch would slip to around 4K RPM (only when pulling away from standstill of very low speeds), then as the revs reached about the 4K mark the box would fully engage & i'd get a kick in the pants.
After a few weeks of this (intermitent) i was heading to my local Audi dealer when the car went into Limp mode (great timing) & locked in 3rd gear. The dealer could not trace the exact problem or rectify, so the entire Tip box was replaced. IIRC the overall bill (under warranty) was around £13K. It's engine out & about 80hrs labour.
Good luck.
Good luck.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
RE: GEARBOX on RS6
Paul ... £13k !!!!!!!!!!!!!! Holy smoley.
Just out of interest then, how did you convince the dealer to repair it under warranty when the car was so heavily modified ?
Re: RE: GEARBOX on RS6
A very good question & it was 50/50 relationship & the fact other boxes had failed (on standard cars) so they did not push back due to my mods.Wolverine wrote:Paul ... £13k !!!!!!!!!!!!!! Holy smoley.
Saying that & the funniest part, the Audi Technicians had to call Sportec for details on how best to re-connect the Sportec Carbon Fibre ducting that graced my RS6 & of course my shiny oversize Sportec Intercoolers as these were not in their workshop manual
The horrible part & a sight i'll never forget, was looking through the workshop viewing window & seeing my RS6 with no front end & my Engine hanging from a hoist just infront of my car. It took them 2 weeks to complete the work & the bulk of the cost was labour which IIRC was around 80hrs at Audi rates
Paul
RE: Re: RE: GEARBOX on RS6
13k???!!
I can confirm that a gearbox install on the RS6 is 24 hours labour, with 3k for the box, 2k for the labour so total bill should be more around the 5k mark.
Maybe they prices were much higher when you had yours done Paul?
Also I think you may have been quite lucky with your mods, these days, dealers take MAF and Boost logs and send them to Audi UK, and spit out any warranty claims if Audi UK confirm the readings are outside manufacturing specs.
As we're on the subject of gearboxes, I have a quick question.
When in "Neutral" and putting into "Drive" i notice two knocks of engagement into drive.
One i can understand but two?
Anyone have an answer to this?
(Sorry to hijack the thread)
Re: RE: Re: RE: GEARBOX on RS6
I know Preston Audi's hourly rate was close to £100 when my box was replaced (they've quite flashy premisesgolfather wrote:13k???!!
I'd still no doubt get away with this now, however i am glad i don't now own such a highly modified car.
Paul
Users browsing this forum: No registered users and 44 guests
