Hi,
Can someone tell me how I can check the S6 (2001 model) throttle is fully opening via Vag com?
cheers
S6 Throttle checking
RE: S6 Throttle checking
give us the codes , spoke with tony, will help if pos.
OK looked at codes this is a simple issue.
Your secondary air is only used on start up and this little air pump may not be starting.
All this system does is fool the lambdas to not knowing the system is rich on start up.
Easy fix mate, just get it looked at.
Gear box , get it booked in and replaced.
You must log in detail the gb issue and ask to See it in writing.
Even write to mondial or Audi with your concerns.
Got your codes from tony.
Cheers for that
I think they have sorted the air issue by replacing perished pipes.
So knocking could be auto box then and get it looked at asap, I am only on 2 month car plan warranty at present, so might take it to Audi and then get then to look first then claim it back you think?
Also anyone know any good warranties to go for, warranty direct etc?
Users browsing this forum: No registered users and 60 guests
