Alignment great - Transmission leak bad - help
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Si4
Post by Si4 » Wed Dec 27, 2006 3:34 pm
Help..
just had my wheels aligned - really makes a difference.. should be added to the "things you should do when you get an S4" sticky.
BUT.. whilst under the car we noticed that i have transmission fluid everywhere. There's a banjo on the side of the transmission and it's leaking badly. Is this an AUDI job, 200 mile round trip to MRC, or can us amateurs have a go? :?: it's really easy to get at.
advice gratefully received
cheers
'99 S4, RS4 shocks, Ali mirrors, MTM reps, 710n's, W8 Under tray and the much loved after run pump mod.
S2tuner
Trader (Expired)
RE: Alignment great - Transmission leak bad - help
Post by S2tuner » Wed Dec 27, 2006 3:42 pm
The banjo is probably the connection for the gearbox cooler, it's quite a big bolt size, try to tighten it up gently and without breaking it...
Have you had your clutch done recently? I can't see any reason why that banjo would start leaking out of the blue...
Mihnea
Si4
Post by Si4 » Wed Dec 27, 2006 3:59 pm
cheers - i'll try it. lost a lot of fluid so i'll need to top up the fluid - how hard is that?
you have pm
grizz
Post by grizz » Wed Dec 27, 2006 5:04 pm
The gear box only has 3 lt of oil in it , so i would not use the car until the oil topped up !!!! The last thing you want is to run the box dry !!!!!!!
Unit 20
0151 3366888
Si4
Post by Si4 » Wed Dec 27, 2006 5:26 pm
i'm not risking it.. there's so much oil all over the bottom of the car.. :(
i'll give it a tighten tonight but it needs oil so booked into the stealers for friday
but they're paying for a taxi each way to work :shock:
Poole audi have been impressive since they did a refurb.. but i'll let you know afterwards
QuantumJohn
Post by QuantumJohn » Wed Dec 27, 2006 5:44 pm
Simon,
Whatever you do don't use the car until you know how much oil is in there or it has been topped up to the right level. You don't want to drive the car anywhere with little oil in it - even to the dealers. It will do irreparable damage to the gearbox - don't ask me how I know.
I believe there are 2 copper washers either side of the banjo fitting in which case it could just be these that need replacing.
John
Si4
Post by Si4 » Fri Dec 29, 2006 6:58 pm
Audi diagnosis...
the two copper rings are faulty and need replacing as you all predicted.. leak 1
AND the rear gearbox seal is faulty.. leak 2
parts on back order so could be over a week so i get a car on tuesday till parts arrive but it's going to be 3 hours work at Audi rates... ahhh
on that note.. Audi Poole have been really good so far.. taxi's, wash, wax, vacuum and getting me a car while mine is off the road (and they told me my car was immaculate - how sweet) - unexpected for a stealer
do you think my warranty-direct warranty will cover the rear gearbox seal? - doesn't specifically mention it so probably not!
QuantumJohn
Post by QuantumJohn » Sat Dec 30, 2006 12:21 am
I guess the copper washers are a few pennies each and the rear gearbox seal only a few pounds. Then around £300 to fit them. Wow!
John
saf
Post by saf » Sat Dec 30, 2006 6:21 pm
Thats whay they call them STEALERS!
Users browsing this forum: No registered users and 92 guests
