Gurgling in the wet?
2.7 V6 30v biturbo - 380 bhp
Avus4
Post by Avus4 » Sun Dec 03, 2006 9:04 pm
Hi there. Just wondering if anyone has come across the following problem. In heavy rain my RS4avant can get very noisy , particularly if you hit a deep puddle. Is it sucking in water or is it simply something to do with the exhaust?
I dont want to bend any rods so please help
(PS the car is bog standard.)
Thanks in anticipation
Mike
Jani
RE: Gurgling in the wet?
Post by Jani » Mon Dec 04, 2006 6:47 pm
Same here. I sometimes get that symptom after a longer drive in very wet conditions. Then when I start to engine brake, there is the noise. Like the exhaust touching the body -which I suspect it does. Maybe wet causes the pipe to heat / cool unevenly, making for a bending effect in the exhaust. That causes it to touch the body? Don't know.
Has anyone else had this symptom, or better yet, solved it?
RS4inGermany
Post by RS4inGermany » Mon Dec 04, 2006 6:55 pm
My car is stock and I do not have any problems with this type of noise in the wet. I have been told by my shop if I were to switch to an aftermarket exhaust I would get this gurgling noise when the car is driven in a heavy rain.
tartan_rob
Post by tartan_rob » Tue Dec 05, 2006 4:55 pm
I had this before in a Rover Turbo, it turned out to be the flexi hose on the exhaust becoming water logged. Not sure what is between the flexi cross wires and the main exhaust.
2017 Kawasaki Z1000
2014 RS6
2014 S1
